  3. What's Good About Allegro PCB Editor Replace Padstack? 16…
PCB Layout and routing
Cadence Design Systems
Allegro 16.6
Routing
PCB Editor
Layout
Grzenia
What's Good About Allegro PCB Editor Replace Padstack? 16.6 Has Several New Enhancements!
15 Sep 2015 • Less than one minute read
The Allegro PCB Editor 16.6 ‘Replace Padstack’ command is now available as a context menu item when the selection set consists of mixed padstack instances.  Prior to 16.6, the selection set would have to be limited to common padstacks. This is available in General Edit Application mode.
Read on for more details …
The Options Panel now supports the ‘Ignore FIXED property’. The ‘Pin Number’ field has been enhanced to support a range of values:
I look forward to your feedback.
Jerry “GenPart” Grzenia
