  3. What's Good About the latest RF PCB? New capabilities in…
RF
Cadence Design Systems
16.6
SPB
Grzenia
What's Good About the latest RF PCB? New capabilities in 16.6-2015!
12 Apr 2016 • 4 minute read
The 16.6-2015 RF PCB release contains many new features and updates. Read on for more details …
Allegro Discrete Library to ADS Translator Enhancements
This release includes several enhancements in Allegro Discrete Library to ADS translator. The following image illustrates the latest UI of the tool:
Support for Schematic Symbol Version
You can now define versions for a schematic symbols in the CSV file. On loading a CSV file, a new column is added to the Selected Parts grid. Only those symbols for which a version is defined are translated.
Filter Support for Searching a Library or Part
A filter field is added to search for library part(s).
Associate Selection of Part with Selected Parts Grid
For the parts displayed in the Selected Parts grid, the corresponding libraries are enabled in the tree view.
Support to Select/Unselect All Parts
When the Select/Unselect all check box is selected, all the library parts are added for translation and displayed in the Selected Parts grid. Similarly, disabling this checkbox clears all the selected libraries from the Selected Parts grid.
Performance Improvement
The response time of translator GUI is reduced. The translator no longer parses all the libraries to display the GUI, and improves the performance as a result.
Non-Graphical Mode for Batch Translator
The batch command is enhanced to run the translator in a non-graphical mode using a new option, -auto. This option suppress all graphical user interfaces including the splash window, translator main dialog, and progress window.
Preserve Casing of a Layer Name in the Mapping Process
The mapping process of the translator now preserves the casing of the layer name in ADS and also displays the layer name in the Edit Layer Map dialog:
IFF Import and Export Enhancements
The RF IFF Import and RF IFF Export commands are enhanced to support the editing of layer map files. You can edit the current layer mapping settings using a text editor and save them in a text file.
RF IFF Import
New options are provided in the RF IFF Import to export and import layer mapping settings:
For more information, see Allegro PCB Editor to ADS (Export IFF) in Allegro User Guide: Working with RF PCB.
RF IFF Export
In RF IFF Export interface, the layer mapping settings can be edited by enabling a new option, Layer map new mode in the More Options dialog. The RF IFF Layer Map dialog presents options for importing, editing, and restoring the current layer mappings:
For more information, see ADS to Allegro PCB Editor (Import IFF) in Allegro User Guide: Working with RF PCB.
Manual Placement Command
In 16.6-2015, a new rf_manualplace command is added to support the functions of placing components that are not available with the existing autoplace command:
 rf-pcb menu
Using the Manualplace command you can interactively place revised or unplaced components in the design. You can also select multiple components and place or update them sequentially. This command lets you easily check the schematic changes after the netlist is re-imported. On selecting a component, the cursor dynamics changes and show the outline of the component. Before placing the component you can select a pin to fix for the autoshoving:
While placing or updating a component, you can perform the following actions:
  •      rotate the component
  •      skip the current component and select next component from the list
  •      select start pin
  •      snap to the pad edge of etch object or any other component
  •      create clearance assembly or merge into existing assembly of surrounding objects
  •      auto-shove of placed objects that are connected to the component
Miscellaneous Enhancements
Cross-probing between DE-HDL and PCB Editor
When you edit an RF design and select an RF component or its pins in Design Entry HDL, the corresponding pins of the component are selected in PCB Editor.
The cross-probing between Design Entry HDL and PCB Editor works only if they are launched from Project Manager.
On cross-probing an RF component or its pin, rf_manualplace command becomes active in PCB Editor and lets you place or update the component:
Support for Rotation-Pick Mode in Placement Commands
In this release, the component placement commands support a new rotation-pick mode. In this mode, you can rotate the component before picking a destination.This mode is available for the following commands:
     rf_autoplace
     rf_manualplace
     rf_add_component
You can start the rotation-pick flow using the new right-click pop-up menu, Rotate. The following figure shows the updated right-click menu for rf_autoplace, rf_manualplace, and rf_add_component commands, respectively:
I look forward to your feedback.
Jerry “GenPart” Grzenia
