  3. What's Good About ADW’s Configuration Manager? Look to 16…
Allegro 16.6
16.6
Allegro Design Workbench
Library flow
Library and design data management
SPB
design
Grzenia
Librarians
library
What's Good About ADW’s Configuration Manager? Look to 16.6 and See!
12 Feb 2013 • 1 minute read
The 16.6 Allegro Design Workbench (ADW) Configuration Manager has been enhanced!
There is an enhanced focus on software serviceability and an improved ease of use environment for managing:
  • Software updates & version status
  • Configuration Files & Database updates
  • Single cockpit to monitor global server topology
    • Easy to use dashboard for Server connection status
  • Server topology
A new ADW Server Setup Wizard provides the ability to quickly install the server and clients.
The Sever Management Tools provide:
–    New server set up wizard
–    Start/stop server
–    Server status logs
You can now setup a schedule for Library Distribution and Distribution status monitoring.
Read on for more details …
Here’s the new Configuration Manager:
You can setup a Master or Design type server:
The new map display indicates the various servers around the globe and their status:
A green icon indicated the server is running (yellow means it’s stopped). You can hover over the icon to determine the name, description and status. A Right Mouse Button (RMB) on the icon controls other options:
Here are the various options when you select Configure Library Distribution:
As always, I look forward to your comments!
Jerry “GenPart” Grzenia
