  3. What's Good About Allegro GRE Rake Functionality? You’ll…
SPB16.3
global route
Routing
Allegro 16.3
SPB 16.3
SPB
PCB Editor
Layout
"PCB design"
GRE
What's Good About Allegro GRE Rake Functionality? You’ll Need the SPB16.3 Release to See!
15 Sep 2010 • 1 minute read
The SPB16.3 Global Route Environment (GRE) Expanded Rakes functionality provides better visualization of the connectivity of the Bundles. In previous versions, this functionality was only provided when the user moved the gather point. Now this functionality is provided at two levels – the design level through Design Parameters, or at the individual bundle level through the Bundle’s properties.
For more information, read on …
_________________________________________________________________
If you set the Expanded Rake view at the Design Parameters level, it will by default set the Expanded Rakes to be visible when you create a Bundle. You view the Design Parameters Expanded Rake setting by using the Pop-Up (RMB->Quick Utilities->Design Parameters) or Setup->Design Parameters->Flow Planning->Default Bundle Properties.
If you set the Expanded Rake view at the Bundle Properties level, it will set the Expanded Rakes to be visible regardless of what the Default Parameters setting is. You can get to the Expanded Rake settings on the Bundle properties dialog by hovering over a bundle or bundles and RMB->Bundle Properties.
Also, when doing other Bundle Edit functionality such as Split Bundle or Copy Flow, the current setting of the Expanded Rake will propagate forward to the new Bundles.
Please share your comments on this new capability.
Jerry "GenPart" Grzenia
