  3. What's Good About Allegro PCB Editor CM Analysis Control…
constraints manager
Cadence Design Systems
Constraint-driven PCB Design flow
data management
constraint databases
Allegro GUI
Allegro 16.6
cadence
16.6
SPB
PCB Editor
Constraint Manager
PCB routing
design
Constraints
Grzenia
Constraint Driven PCB routing
PCB Capture
What's Good About Allegro PCB Editor CM Analysis Control? 16.6 Has a Few New Enhancements!
3 Feb 2014 • Less than one minute read
Beginning with the 16.6 version of Allegro PCB Editor, you can now toggle the Analysis flag directly from the Constraint Manager (CM) column header without using the “Analysis Modes” dialog.
Read on for more details …
The Constraint Manager column’s header is colored in yellow in case the related Analysis is set to OFF.
Here is a screenshot from the Electrical Worksheet > Net > Routing > Wiring:
In the Analysis mode you will see that the related DRC modes are OFF:
Click the right mouse button on a column header and select the Analysis Modes menu item:
Selecting Analysis Mode will set the related Analysis to ON and the header color will not display it as yellow:
Please share your experiences using this new capability.
Jerry “GenPart” Grzenia
