  3. What's Good About Allegro PCB Editor Place Replicate Text…
PCB Layout and routing
place replicate text support
Allegro GUI
Allegro 16.6
16.6
Placement Edit
place replicate
PCB Editor
Layout
"PCB design"
Grzenia
What's Good About Allegro PCB Editor Place Replicate Text Support? Check Out 16.6!
4 Mar 2013 • 1 minute read
The Allegro PCB Editor Place Replicate application now supports the processing of component reference designators. The work performed in customizing assembly text or silkscreen to the seed circuit can now be leveraged across the replicated modules.
Read on for more details…
In the image below there are two modules. The one on the left (U14, U15 and the associated capacitors) has the text moved to locations which were determined to be appropriate. The module on the right would need to be updated to reflect the same text placement:
Once you have customized the text locations, use the Place Replicate 'Refresh' application to update the second circuit. The steps are:
1.    Set the 'Super Filter' to 'Module'
2.    Hover over the seed circuit then RMB — Place replicate — Update. Select/unselect additional etch as needed.
3.    RMB — Done. This will launch the file browser UI in which you can select the module you would like to refresh. Selecting the module and performing a save will update the module on disk and update the module(s) in the design.
As always, I look forward to your comments about this new capability.
Jerry “GenPart” Grzenia
