  3. What's Good About Allegro PCB Router Staggered Via Rules…
PCB Layout and routing
global route
Routing
staggered vias
Allegro 16.5
via rules
PCB Editor
Layout
vias
SPB16.5
What's Good About Allegro PCB Router Staggered Via Rules? See for yourself in 16.5!
6 Mar 2012 • 1 minute read
Just a quick blog today on a new 16.5 Allegro PCB Router enhancement for Staggered Via Rules.
The stagger gap value is defined by rules at the following levels:
  • PCB
  • Layer
  • Class
  • Net
  • Region
Option Descriptions:
on - turns the rule on.
off - turns the rule off (default)
min_gap - controls the minimum distance between consecutive vias in the pattern.
If min_gap is not specified, a proper samenet bbvia/microvia to samenet bbvia/microvia clearance rule in effect controls the distance. An assigned negative value means no restricted min distance between consecutive vias in the pattern
max_gap - controls the maximum distance between consecutive vias in the pattern. If max_gap is not specified (or assigned a negative value) any restrictions exist on max distance between consecutive vias in the pattern.
Examples:
#define PCB level rule for staggered bbvias/microvias
rule PCB (staggered_via on (min_gap 0.1) (max_gap 0.8))
#redefine rule for staggered bbvias/microvias at ‘3_LAYER’
rule layer 3_LAYER (staggered_via on (min_gap 0.2) (max_gap 0.7))
#redefine rule for staggered bbvias/microvias of nets #from ‘NET_CLASS1’ class
rule class NET_CLASS1 (staggered_via on (min_gap 0.3) (max_gap 0.6))
#disable PCB level rule (similar rules at different hierarchy #levels are left enabled)
rule PCB (staggered_via off)
COST of Via Stagger Violation:
Cost descriptor values are interpreted by the PCB autorouter as follows:
- Forbidden, wrong staggered bbvia patterns aren't allowable for building (default)
- High, additional cost on wrong staggered bbvia patterns 100
- Medium, additional cost on wrong staggered bbvia patterns 25
- Low, additional cost on wrong staggered bbvia patterns 8
- Free, no additional cost on wrong staggered bbvia patterns
Note: At the “converge” stage (either after 5th routing iteration or during “filter” command execution) the autorouter resets this cost to the forbidden value automatically.
I look forward to your input on this capability.
Jerry "GenPart" Grzenia
