  3. What's Good About Allegro Placement Replication / Fine Tuning…
SPB 16.2
SPB 16.3
Allegroro
What's Good About Allegro Placement Replication / Fine Tuning? - Look to SPB16.3 And See!
6 Jan 2010 • 5 minute read
Placement replication was introduced in Allegro PCB Editor SPB16.2. At that time, the application was limited to replication of component placement. The SPB16.3 release introduces the support of etch circuits (shapes, clines, vias) as well as ease of use improvements associated with basic move, mirror and rotate functions. Once replicated circuits are placed, physical changes such as moving components or modifying etch circuits are easily instantiated across all instances with a new update command.
The methodology for creating and applying replicated circuits is similar to that of SPB16.2 however the stored file format is different due to the support of etch and the refresh capability. The file format leverages the legacy module (.mdd) database structure and replaces the circuit replicate file (.crf) format. SPB tools continue to support the front end driven re-use flow and the backend driven placement replication which is schematic neutral. Placement replication files can be leveraged across different designs containing common circuitry blocks such as decoupling schemes for high pin count devices, memory arrays, and IO channels
Placement replication is only available within the "Placement Edit" application mode environment. The use model requires the pre-selection of symbols followed by a RMB action command.
Aligning modules and replicated circuits
The alignment of re-use modules and place replicate circuits is now supported in Placement Edit Application mode. The use model is similar to the Align Components command that was introduced in 16.2. The three step process begins with a window selection of the module circuits; hover over a symbol within the circuit you wish all others to be aligned to and then using the right mouse button command "Align Modules" to perform the alignment.
Using the commands
1. Enter the placement application mode.
2. With the seed circuit placed, window select all of the components followed by a right mouse button "Place Replicate Create." When accessing the right mouse "Place Replicate Create." menu item be sure to hover over a component element, such as a pin, in order to get the right mouse button menu. Hovering over black space will not produce the commands related to the selected elements.
All intra connected circuitry will be highlighted.
 3. You will be given the opportunity to select or unselect additional etch from that which was auto-generated for the seed circuit. A typical application may be to extend the circuit to include I/O.
At the Allegro command window you will be prompted "Select/unselect additional etch as needed, then click Done." Select or unselect additional etch elements using the combination of the left mouse button and the control key. In the image below the 5 clines off of U120 were selected.
4. You will be prompted to "Pick origin or use RMB for Snap to" functionality. Use the Snap to functionality to snap to a pin or via or other element.
5. You will be prompted, with a GUI to save the seed circuit. It will be stored in .mdd format.
6. Window select the remaining components that you want to replicate followed by a right mouse button "Place Replicate Apply". You can either continue in the right mouse button selection to select the replication module or select "Browse" to use a GUI to select the module.. Minimize the selection to relevant components to minimize any performance impact.
7. The following interface appears which lets you swap components. The first column lists the contents of the next circuit to be placed, the second column lists the swappable components in that circuit. When a component is selected in the "Swappable" column, a list of components to swap with appears in the "Swap With" column.
8. Selecting "OK" will place the replicated circuit on your cursor.
9. Place all of the circuits. Care doesn't need to be taken to place them in proper alignment.
10. Window around all of the replicated circuits, including the seed circuit, and select right mouse button "Align Modules" while hovering of a component that you wish the other circuits to be aligned to.
11. If a change needs to be made to the circuitry you can make those changes and then update those changes to the other replicated modules. IN the image below some delay has been added to etch.
12. Set the super filter (right mouse button) to "Module". Hover over the circuit that the changes were made to and select, using the right mouse button, Place replicate apply. You will be prompted to select/unselect additional elements and then select "Done".
13. A file save GUI will be presented to you where you can save the circuit. At that time the updates will be applied to the circuits in the design.
-14. While you are in the placement application mode and the super filter is set to "Module" you can move the replicated circuit as a group by hovering over the module and selecting "Move". You can also take advantage of single pick functionality by enabling the right mouse button functionality "Customize -- Enable Single Click Execution." Using this you only select the module to move rather than hovering over the module and selecting "move" from either the right mouse button or the Allegro menu.14. While you are in the placement application mode and the super filter is set to "Module" you can move the replicated circuit as a group by hovering over the module and selecting "Move". You can also take advantage of single pick functionality by enabling the right mouse button functionality "Customize -- Enable Single Click Execution." Using this you only select the module to move rather than hovering over the module and selecting "move" from either the right mouse button or the Allegro menu.
As always - I welcome your feedback and suggestions on using the new SPB16.3 features.
Jerry "GenPart" Grzenia
