  3. What's Good About Allegro Router and Via Changes? SPB16…
PCB Layout and routing
SPB16.3
Routing
specctra
Allegro 16.3
layer stacks
SPB 16.3
SPB
PCB Editor
Layout
via
microvia
What's Good About Allegro Router and Via Changes? SPB16.3 Has a Few New Enhancements!
20 Oct 2010 • 3 minute read
This week, I’ll be closing discussions on the new SPB16.3 Allegro PCB Router improvements. The focus is on several enhancements for via support.
The Use_Via Rule
Many times you need to restrict the usage of specific vias in a region. Allegro PCB Router has been enhanced in the SPB16.3 release to allow via usage in a certain region. The use_via rule has been enhanced to align with the Allegro via list functionality. The following objects support the use_via rule:
1.    region
2.    region net
3.    region class
New physical rules look like following:
circuit region <region_name> (use_via {[<padstack_id>]})
circuit region_net <region_name> (use_via {[<padstack_id>]})
circuit region_class <region_name> (use_via {[<padstack_id>]})
Specifying Vias for a Region
Via rules can be specified in Allegro Constraint Manager.  Open Constraint Manager > Physical > Region > All Layers and select the vias for regions. The rules specified in Constraint Manager are transferred to the Router:
The rules are translated to a “do” file as shown in the example below:
Reports
Use via conflicts are reported as a type option to the ‘report conflict’ command:
report conflicts window (type use_via)
If any conflicts should be reported according to syntax:
#1: Incorrect Via Padstack Usage "VIA019"
Blind-Buried (BB) Via Clearance
Both the SPECCTRA Router algorithm and DRC engine can differentiate between bbvia and thru via for the same net to net spacing requirement.  In the SPB16.2 release, only the microvia specific clearances were respected.
Blind Buried Vias Spacing Constraints
The following set of net to net and same net constrains for bbvias are now supported in Allegro PCB Router:
BBvia => bbvia
=> microvia
=> thru via
=> testvia
=> samepin
=> thrupin
=> testpin
=> bondpad
=> wire
=> area
Please refer to Allegro PCB Router Command Reference manual for syntax details.
You can open the Allegro constraint Manager and specify the blind buried clearances.  For example:
Open Constraint Manager > Physical > Net  > All Layers. In the example below different clearances have been applied to net ADSL:
These are translated to the “do” file as shown below:
# rule assignments for net clearances                                          #
rule net ADSL (clearance 1 (type microvia_bbvia))
rule net ADSL (clearance 2 (type bbvia_bbvia))
rule net ADSL (clearance 3 (type bbvia_thrupin))
rule net ADSL (clearance 2 (type bbvia_smdpin))
rule net ADSL (clearance 5 (type bbvia_thruvia))
rule net ADSL (clearance 4 (type bbvia_wire))
rule net ADSL (clearance 6 (type bbvia_area))
rule net ADSL (clearance 2 (type bbvia_testpin))
rule net ADSL (clearance 4 (type bbvia_testvia))
Notes:
1. Object names are case insensitive
2. 'bbvia' is a generalization of buried/blind vias
Enabling/Disabling Blind/Buried Via Spacing Constraints
Bbvia spacing constraints may be enabled/disabled at all levels of hierarchy by the following command:
set <bbvia_condition> on|off
< bbvia_condition >::= bbvia [_<paired_object>] [samenet]
<pairedObject>::= bbvia|microvia|thruvia|testvia|smd pin|thrupin|
testpin|bondpad|wire|area
Same Net Checks
'same_net' keyword attaches the clearance rule to typed objects from same net
For example:
rule pcb (clearance 3 same_net (type bbVia_bbVia))
All samenet rules are enabled/disabled by the ‘set’ command as following:
set same_net_checking on
or
set same_net_checking off
Reports
The current rules are reflected in detailed rules. For example Report > Rules > Net Rules reflects the above rule as shown below:
    Net ADSL:
area_bbvia clearance =    6.0000
bbvia_bbvia clearance =    2.0000
bbvia_smdpin clearance =    2.0000
bbvia_testpin clearance =    2.0000
bbvia_testvia clearance =    4.0000
bbvia_thrupin clearance =    3.0000
bbvia_thruvia clearance =    5.0000
bbvia_wire clearance =    4.0000
Highlight/Unhighlight bbvias
The following SPB16.3 SPECCTRA command is available to highlight/unhighlight selected kinds of bbvias:
        highlight <object_type> [<start_layer> [<finish_layer>]] on|off
object_type::= bbvias | blind_vias | buried_vias
start_layer valid layer name where bbvia starts from
finish_layer valid layer name where bbvia ends at
Notes: bbvias – blind and buried vias are highlighted (unhighlighted)
blind_vias - only blind vias are highlighted (unhighlighted)
buried_vias - only buried vias are highlighted (unhighlighted)
If layers aren’t specified, bbvias from all layers are highlighted or unhighlighted
If only one layer is specified, only crossing this layer bbvias are highlighted (unhighlighted)
on – highlight objects
off – unhighlight objects
Example:
Command > highlight bbvias on
will highlight all bbvias
Please share your experiences with these new capabilities.
Jerry "GenPart" Grzenia
