  3. What's Good About Allegro's Component Placement Changes…
SPB 16.2
Placement Replication
Component Alignment
Allegroro
What's Good About Allegro's Component Placement Changes? - More Features in SPB16.2!
23 Sep 2009 • 3 minute read
In the SPB16.2 release of Allegro PCB Editor, there are two (2) new very helpful features (among the many others) that assist PCB designers with component placement - Component Alignment and Placement Replication.
Component Alignment
  • You can now specify a Vertical or Horizontal alignment of symbols based on their body center.
    • There are no associated options.
  • The feature automatically attempts to determine the axis to align.
    • You'll be prompted for a direction (Vertical or Horizontal) in ambiguous situations.
  • The use model requires the pre-selection of all symbols to be aligned.
    • You can hover over an anchor symbol then right mouse button (RMB) – Align Component.
  • This is a single-sided application.
Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Now the parts are aligned -
  • This is an application designed to replicate common blocks of circuitry.
    • Based on common device and connectivity model.
    • No Front End dependencies other than net list.
  • The process begins by establishing an initial “seed” circuit.
  • The Place Replicate Create function is then used to create a .CRF file with origin point.
    • The CRF (Circuit Replicate File) can be stored in the board DB or on disk for re-use on other boards.
  • The PCB Designer then applies a .CRF to selected group of symbols.
  • The Place Replicate algorithm generates common circuits if matches are found.
    • Available on cursor for placement.
  • Placement Blocks are represented as a Group Object in the Allegro database.
As always, I look forward to hearing how you're using these new features and any recommendations you may have.
Jerry "GenPart" Grzenia
