  3. What's Good About AMS Simulator Fonts, Models, and More…
SPB16.3
AMS
AMS simulator
SPB 16.3
PSPICE
SPB
AMS simulation
Design Entry
library
What's Good About AMS Simulator Fonts, Models, and More? It's in SPB16.3!
6 Oct 2010 • 2 minute read
The SPB16.3 release of the Allegro AMS Simulator environment contains a few additional features (which I've not yet covered in my prior posts) that I'll wrap-up in this post.
Highlighting in circuit and out files
With the SPB16.3 release, the PSpice circuit and out file syntax are presented in easy to read colors that highlight the different groups such as text, numbers, comments, expressions, operator, and keyword. You can also specify your own color schemes for the files by editing the SpiceSyntax.ini file in the <CDS-installation-folder>/tools/pspice directory.
Changing Font Properties
You can now make the labels more readable by changing font size, color, effects, and style.
Also, you can specify default fonts for label text - go to Tools> Options> Probe Settings> Font Settings and click Change label font.
Exporting Comma Separated Value (CSV) File
You can now easily export trace information as CSV files by choosing File Export Comma Separated (.csv file) in the PSpice probe window. The trace information for specified variables will be exported to a location and file you specified and can be read using tools, such as Microsoft Excel.
Faster dat file import and export
In the SPB16.2 release, the performance of large dat files with sizes of 2GB or more was improved. In the SPB16.3 release, the performance enhancement on opening a dat file has been improved for dat files of all sizes.
New Models
More than 330 new models are now available for simulation in the SPB16.3 PSpice release under the following categories:
Pulse Width Controlled (PWM) Models
Linear regulators
Zener Voltage Regulators
Glass passivated Zener Diode
PWM Models
Synchronous PWM buck controllers
MAX 8576
MAX 8577
MAX 8578
MAX 8579
High Speed PWM Controllers
UC 1823
UC 1823A
UC 2823B
UC 3841
High Speed PWM Controllers -- Full bridge Controllers
UC 3825
UC1825_SP
UC1825A_SP
UC2825A_EP
Linear regulators
213 models of Low Quiescent Current, CMOS Linear Regulator from Analog Devices are available in the AD_REG library. The new models are of the following series:
adp120
adp121
adp130
adp3338
adp3339
adp1710
adp1711
adp1712
adp1713
adp1714
adp1715
adp1716
adp1720
Zener voltage regulators
74 Models of Zener Voltage Regulators from Taiwan Semiconductor are available in the
BZT55 library. The models are of the following two series:
BZT55B
BZT55C
37 Models of Glass passivated Zener Diode from Fagor are available in the FAGOR_ZY_GP library.
Please share your questions and experiences using these new SPB16.3 AMS features!
Jerry "GenPart" Grzenia
