  3. What's Good About AMS Simulator IBIS Model Capability? It…
Cadence Design Systems
AMS
Allegro 16.6
cadence
AMS simulator
IBIS
16.6
Capture CIS
Capture-CIS
PSPICE
SPB
design
AMS simulation
Design Entry
Grzenia
What's Good About AMS Simulator IBIS Model Capability? It’s in the 16.6 Release!
6 Oct 2013 • 1 minute read
The 16.6 AMS Simulator now provides IBIS model simulation capability:
  • SPICE circuit generation for all IBIS versions
  • Support for V-T curves
  • Analog simulation of XNets (use Advanced Analysis tools for smoke analysis on bypass components)
Read on for more details …
The Model Editor now supports all versions of IBIS for V-T curves.
Invoke Modeled.exe.
Invoke the IBIS converter from the menu Model > IBIS Translator.
Browse to Database\IBISImport\epcs64.ibs:
Click OK to generate PSpice Model.
PSpice allows you to simulate nets with SI Model assignments in PSpice. Consider the following example circuit:
Select a design from Project Manager and invoke the library setup. Ensure the library setup is correct:
Select pins U1A.16 and U1B.11 and select RMB > Signal Integrity >Assign SI Model:
Assign any output model to the pin:
Open a TCL Command Window in Capture from the menu View > Command Window.
Type in the following TCL command to activate the IBIS netlisting -
SetOptionString IBIS_PINS_NETLIST TRUE
Next, source a TCL file from your hierarchy -
source {$CDSROOT\pspice\tclscripts\IbisToPSpice\tcl\ibisnetlist.tcl}
Create a transient simulation profile Tran.
Generate the PSpice Netlist from IBIS by executing the following command -
::ibisnetlist::run
Run the PSpice Simulation.
Plot V(Mynet).
Create new measurement:
Launch AA for Sensitivity analysis from Capture.
Import measurement.
In the AA TCL Window, enter the following command -
source {<path>\database\SimulatingSI\PspAAProcessDesign.tcl}
Run Sensitivity Analysis.
I look forward to your comments about how you’re using these new capabilities!
Jerry “GenPart” Grzenia
