  3. What's Good About APD’s Assembly DRCs? You’ll Need the 16…
PCB Layout and routing
IC Packaging
DRC
APD
ADRC
Allegro 16.5
SPB
PCB Editor
advanced package designer
Layout
assembly DRCs
"PCB design"
SPB16.5
What's Good About APD’s Assembly DRCs? You’ll Need the 16.5 Release to See!
26 Jul 2011 • 25 minute read
Prior to the Allegro Package Designer (APD) 16.3 release, Design Rule Check (DRC) markers created by Assembly Rule Checks had to be external DRC markers since no constraint IDs were associated with the ADRC constraints.  In the 16.3 release, Constraint IDs were created for each of the rules. It enabled us to make a change to DRC markers.  For the 16.5 release, each Assembly DRC (ADRC) rule gets its own marker based on constraint ID.
APD’s ADRC DRC markers will look and behave similar to all DRCs. ADRC markers will differ for different rule checks (or groups of related rule checks), rather than all appearing the same as it was with using External DRC markers.  ADRC DRCs will have their own worksheet in Constraint Manager instead of being combined with External DRC markers.
Differences between current (external) DRC behavior and constraint ID based behavior are as follows:
CURRENT
CONSTRAINT ID Based
Comments
When object that has DRC Marker attached is moved
DRC Marker stays at previous location (unattached )
DRC marker deleted
( without warning)
This will display the message that the disappeared marker doesn’t mean that there is no error any longer, just that the ADRC rules have to be re-run.
Update DRC command
Doesn’t have any effect on ADRC DRC markers
Update DRC will not affect ADRC DRC markers, similar to batch DRCs run by the rest of the system
When object that has DRC Marker attached is deleted
DRC Marker  deleted
DRC Marker  deleted
No change in behavior
Reports > DRC report
Reports ADRC DRCs as any other in the system
Read on for more details ...
Show element difference
16.3:
Constraint ID based in 16.5:
DRC marker difference
16.3:
16.5:
DRC marker 2 letter combinations
Lower case letters for 2 letter combinations are used for the DRC bow-tie marker.
Existing online wire rules already have 2 letter combinations and they are upper case letters.
They are:
Wire Length ( minimum)
WA
Wire Length ( maximum)
WI
Wire Maximum Angle to Die Edge
WA
Finger to Component Spacing
FC
Wire to Finger Spacing
WF
Wire to Pin Spacing
WP
Wire to Wire Spacing
WW
Wire End to Wire End Spacing
WE
 There are no changes to existing DRCs.
 ADRC batch rule combinations:
Group
Rules in the group
Wire Physical
Wire Length over Parent Die
wl
Wire Physical
Wire Length over Lower Die
wl
Wire Physical
Wire Maximum Angle to Finger
wa
Wire Spacing
Wire Substrate End Distance inside soldermask
ws
Wire Spacing
Wire to Component Spacing
wc
Die Physical
Die Overhang
oh
Die Physical
Die Pad Pitch
pp
Die Physical
Die Pad To Lower Die Overhang
oh
Die Physical
Die Pad to Upper Die Spacing
pd
Die Spacing
Die to Connected Finger Spacing
df
Die Spacing
Die To Finger Spacing
df
Die Spacing
Die to Package Edge Spacing
de
Die Spacing
Die To Die Spacing, Connected Dies
dd
Die Spacing
Die To Die Spacing, Unconnected Dies
dd
Optical
Wire to Die Pad Optical Short
os
Optical
Wire to Finger Optical Short
os
Optical
Wire To Wire Optical Short, Die to Die
os
Optical
Wire to Wire Optical Short, Die to Substrate
os
Die Stack
Center to Center Delta, Extends Based
cc
Die Stack
Center To Center Delta, Pin Based
cc
Die Stack
Die Stack Height
sh
Die Stack
Die Stack to Die Stack Spacing
dd
Die Flag
Die Flag to Die Flag Spacing
xx
Die Flag
Die Flag to Discrete Component Spacing
xc
Die Flag
Die Flag to Finger Spacing
xf
Die Flag
Die Flag to Package Edge Spacing
xe
Solder Mask
Continuous Solder Mask Coverage
sm
Solder Mask
Minimum Solder Mask Shape
sm
Solder Mask
Minimum Solder Mask Void
sm
Solder Mask
Solder Mask To Die Edge Spacing
sd
Solder Mask
Solder Mask to Package Edge Spacing
se
Solder Mask
Solder Mask To Solder Mask Spacing
ss
Package Substrate
Any Metal To Any Metal Spacing
mm
Package Substrate
Cline to Via Overlap
vo
Package Substrate
Conductor to Package Edge Spacing
me
Package Substrate
Discrete Component Pad to Finger Spacing
pf
Package Substrate
Discrete Component Pad to Package Edge
pe
Package Substrate
Exposed Metal to Exposed Metal Spacing
mm
Package Substrate
Finger to Package Substrate Spacing
fe
Package Substrate
Minimum cline segment
cs
Package Substrate
Trace Extension from Finger
te
Package Substrate
Via to Package Substrate Edge Spacing
ve
Shape
Acute Angle Shape Boundary
aa
Shape
Minimum Shape Check
ms
Shape
Minimum Void Check
ms
Acute Angle Metal
Acute Angle Routing
aa
Acute Angle Metal
Merged Metal Minimum Angle
aa
Acute Angle Metal
Trace Minimum Angle to Pad
aa
Acute Angle Metal
Trace Minimum Angle to Shape
aa
Acute Angle Metal
Trace Minimum Angle to Trace
aa
Miscellaneous
Conductor Shape Void Overlap
vo
Miscellaneous
Degassing Void Overlap
vo
Miscellaneous
Tombstone Check
ts
DRC Display in Constraint Manager
New Assembly Worksheet in the DRC domain of the Constraint Manager where assembly DRCs will be displayed:
Note: Uprev and downrev will remove all existing ADRC DRC markers and display a message in the console (as well as in the uprev/downrev log file) to run ADRC again.
Please share your experience using this new capability.
Jerry "GenPart" Grzenia
