  3. What's Good About Capture’s Update Cache? 16.6 Has a Few…
capture
Cadence Design Systems
Allegro Design Entry
Allegro 16.6
Design Entry CIS
cadence
OrCAD Capture
16.6
Capture CIS
Capture-CIS
SPB
OrCAD
Design Entry
Grzenia
What's Good About Capture’s Update Cache? 16.6 Has a Few Enhancements!
3 Oct 2013 • 1 minute read
The 16.6 OrCad Capture release now allows you to replace multiple cache parts in one operation. In addition, all options of Replace Cache now work on Update Cache.
Read on for more details…
In earlier releases, you could not use the options available under “Replace Cache” for “Update Cache” operations. You now have the option to select multiple parts in cache and replace them in one operation:
Replace Cache option in OrCAD Capture
OrCAD Capture Replace Cache dialog box
Consider the following example. Expand the “Design Cache” folder in project window – there are two listings of 74ALS573:
Example of duplicate items in design cache folder
Select both the items listed with 74ALS273and select RMB “Replace Cache”:
Select the 74ALS.olb library from Cadence installation hierarchy and select the 74ALS273 gate from it. Press OK. Note that multiple parts were updated using the “Replace Cache” options.
Please share your experiences using this new capability
Jerry “GenPart” Grzenia
Related Resources:
OrCAD Capture
