  3. What's good about database parameters and XML import/export
PCB Layout and routing
XML import/export
SPB
SPB16.01
OrCAD PCB Editor
What's good about database parameters and XML import/export?
12 Aug 2008 • 1 minute read
In the SPB16.01 release, you can now import/export database parameters from Allegro PCB Editor in the standard XML format using the File> Export/Import> Parameters menu option.
The export functionality creates the parameter file (with a .prm file extension). The parameter file contents can be the following options.
  • Design Setting ( Global values and grid settings)
  • Artwork (Artwork film, film block and film class)
  • Color (Color parameter and color table)
  • Text Size (Text size table)
  • Application or Command Parameters (All the other supported parameters)
Once you've exported parameters from an exiting board file, they an be imported into a new board file using the Board Wizard
In addition, you can use th batch mode for techfiles to read and write database parameter files.
Command syntax:
techfile -r|-w -p [-o <paramtype> -o <paramtype ...] [<paramfile >] [<in design>] [<out design> ]
Modes (one of the following is required):
  • -r - read a paramfile into a layout
  • -w - write a paramfile from a layout
  • -p - reader/writer performs on parameter file, otherwise techfile.
  • -o - parameters to output from a database. Default is to export all supported parameter records. It works with -w switch only.
Import
The techfile executable can be used to read a parameter file into an existing board.
Command syntax:
techfile -r -p [<paramfile> <layout>] [new_layout]
Export
The techfile executable can be used to export a parameter file from an existing board.
Command syntax:
techfile -w -p [-o <paramtype> -o <paramtype ...] [<layout><new_paramfile>]
So, how many PCB designers are taking advantage of importing/exporting XML database parameters to seed board files? While we stress that editing the XML files should be avoided, I'm curious if some adventurous individuals are doing something novel with exported XML files to inject special conditions.
I'd like to hear from you.
