  3. What's Good About Differential Impedance in Allegro Constraint…
PCB SI
SI
RF
SPB16.3
SiP
Signal Intregrity
Digital SiP design
DRC
Allegro 16.3
SPB 16.3
design
SI analysis and modeling
Differential Pair Support
power
What's Good About Differential Impedance in Allegro Constraint Manager? It's in SPB16.3!
22 Sep 2010 • 2 minute read
The ability to constrain or report Differential Impedance from within Constraint Manager (CM) has been a long standing request. The SPB16.3 Allegro PCB Editor Advanced Constraints feature allows customization of a user-defined differential impedance constraint in CM.
Constraint Manager has the ability to report and Design Rule Check (DRC) single-ended impedance in the Electrical domain, Net — Routing — Impedance worksheet. Differential impedance can be added as a user-defined constraint to a new or existing worksheet.
Read more for how to use this new capability.
1. Open the Electrical domain in Constraint Manager (CM).
2. Right mouse button (RMB) click on the Net folder in the tree view and select Customize Worksheet. This will put CM in Customize Mode.
This is indicated by the extra plus signs in the tree view and the check mark next to Customize Worksheet as seen in the graphic below.
3. RMB on the Net folder again and select Add New Workbook.
4. If desired, click on the new Workbook/Worksheet you just added and rename them.
5. Open the new Worksheet you created.
6. RMB on the new Worksheet and select Add Column.
This launches the Add Column dialog, which can be used to add pre-defined and user-defined columns throughout CM and can also be used as a launching pad for creating user-defined columns for things like Measurements, Properties, or User-Defined Constraint Bundles.
7. Change the Type: pulldown to Pre-defined and scroll down in the window until the DIFF... entries are seen.
The items in the Pre-defined list are all of the Cadence attributes in the database and columns in CM. The DIFF_IMPEDANCE_RULE is an example of optional customization that is made available to users.
8. Select DIFF_IMPEDANCE_RULE in the list and OK the Add Column dialog.
9. OK the confirmer that appears. This is merely an indication that the attribute you are adding is enabled for Objects that are not available in the current worksheet.
CM should look something like the following:
The column header and individual columns look like any other constraint in CM. As user-defined constraints, they have the limitation of indicating pass/fail solely within CM. There will be no DRC markers associated with these.
This constraint has a default value of 100 +/- 5 ohms.
10. RMB on the column header and select Analyze to update the worksheet. The values in the Actual column are the min and max values from the range of values found along the differential pair -- similar to the way single ended impedance is reported.
Please share how you're using this new capability in the SPB16.3 release.
Jerry "GenPart" Grzenia
