  3. What's Good About New Smoke Analysis Devices? Check out…
SPB 16.2
AMS simulator
Smoke Analysis
model editor
What's Good About New Smoke Analysis Devices? Check out the SPB16.2 Release and See!
13 May 2009 • 2 minute read
The AMS Simulator Smoke Analysis has been enhanced in the SPB16.2 release to support a few new devices. Also, the  Model Editor now supports the addition of smoke parameters to devices like LEDs, Zener Diodes, Varistors, etc.
The following new devices are now supported by Smoke Analysis:
  • Electrolytic Capacitor
  • Inductor for DC Current
  • VSWITCH
  • Transformer (Single and Double Winding)
In addition, smoke parameters can be added to the following new devices in the Model Editor:
  • LED
  • Zener Diode
  • Varistor
  • Diode Bridge
  • GaAs MESFET
  • Thyristor
  • Voltage - Controlled Switch
  • 4 Pin Optocoupler
  • NPN - PNP
  • NMOS - PMOS
  • Dual BJT
  • Dual MOS
  • Transformer
Smoke Analysis parameter details:
Capacitor
New model params ESR, RTH, and POWER have been added to CAP devices. This corresponds to smoke checking for power loss and temperature rise of capacitors.
Smoke Test Name        Symbol param Name        Symbol parameter Value
“PDML”                              “ESR” & “POWER”                 "ESR" & "CPMAX"
“TJL”                                  “RTH”                                     "RTH"
"CV"                                  "VOLTAGE"                            “CMAX”
"CI"                                   "CURRENT"                            “CIMAX”
"SLP"                                "SLOPE"                                “CSMAX”
"TBRK"                             "KNEE"                                   “CBMAX”
"TMAX"                             "MAX_TEMP"                          “CTMAX”
In addition  two more params CVN (Max -ve voltage) & CVP (Max +ve voltage) have been added to the electrolytic capacitor analog\C_elect.
Resistor
New model param RV (maximum voltage) has been added to RES devices. This is a smoke check for the voltage rating of resistors.
Inductor
New model param CURRENT (maximum DC current) has been added to IND devices. This is a smoke check for saturation of inductors due to DC current.
Voltage Switch
New model params CURRENT, VOLTAGE, and POWER have been added to the Voltage Switch. This corresponds to smoke checking for max current through contact, max voltage difference between nodes NODE_SW_1 & NODE_SW_2, and power deration of the switch respectively.
"SV"                                    "VOLTAGE"                                    “?”
"SI"                                      "CURRENT"                                   “?”
"PDSW"                               "POWER"                                      "?"
Symbol parameter values need to be added on symbol in schematic
Transformer
New model params have been added to transformer (single winding):
"Primary_Current"               "P_CURRENT"                   “?”
"Secondary_Current"          "S_CURRENT"                    “?”
"Isolation_Voltage"             "ISOLATION"                      “?”
Addition of Smoke Parameters in Model Editor:
In order to add smoke parameters to a device from the Model Editor, go to Model> Add Smoke and chose the appropriate device type.
As always, I welcome your feedback!
Jerry "GenPart" Grzenia
