  3. What's Good About Up-Reving in DEHDL? You Can Easily Do…
Allegro Design Entry
hierarchy
DEHDL
electrical constraints
uprev
property
Allegro 16.5
SPB
Design Entry HDL
Front-end PCB design
Design Entry
SPB16.5
ConceptHDL
What's Good About Up-Reving in DEHDL? You Can Easily Do This in 16.5!
24 Aug 2011 • 3 minute read
All Allegro PCB Editor designers know about the uprev process to migrate PCB .brd files from prior SPB releases to a newer release. The Allegro Design Entry HDL (DEHDL) designers rarely need to uprev. With the 16.5 release, however, you will need to uprev designs.
The 16.5 release includes major architectural changes aimed at providing a Design Aware DEHDL with a dynamic connectivity model. In the new architecture, there is no need for design expansion and working at different modes. In order for any existing design to work in the 16.5 release, the design needs to be upreved. This uprev process will make the existing design compatible to work with the 16.5 release DEHDL software.
Read on for more details …
When you open any pre-16.5 release design in the 16.5 release, the tool auto-detects the need to uprev. The uprev utility is also available as a batch command and can be executed on the designs without opening the DEHDL schematic editor. You can also write some simple scripts and run the operation to uprev all the pre-16.5 designs. The process works like the Save Hierarchy operation. Each hierarchical block of the design is read and then upreved to the 16.5 release. The process is quite fast and the complete design hierarchy is updated to the 16.5 release.
Note: To open pre-16.5 release designs that have constraints on the schematic, you first need to synchronize the constraints. The designs will be upreved only after the constraints have been synchronized in the schematic using Tools> Constraints> Synchronize.
You can run the following command in batch mode to synchronize the constraints:
concept2cm -proj <project.cpm > -export -forward -uprev
The uprev process does not modify any of the schematic sheets. However, you will notice that some changes have been made to the file structure. In the new architecture, Constraint Manager (CM) will be used for managing properties and constraints. All this information will now reside in a single database -- the CM database (*.dcf file). The CM database (*.dcf) file will now be stored in the sch_1 view only and therefore a "constraints" view is no longer required. Since the CM database (*.dcf) file will store the properties, there is no need for the viewprop.prp file in the sch_1 view and Occurrence Property (*.opf) file in the opf view. This leads to the elimination of two views – the constraints view and the opf view.
The requirement for generating and analyzing the Verilog netlist has also been removed from DEHDL. This has been made possible by the introduction of a new file which now stores the design connectivity. The design connectivity file is XML based file and will have the extension of 'xcon' (*.xcon). This file helps in loading the design with the complete design connectivity information very quickly and also enables incremental netlisting.
The table below summarizes the changes that occur to the schematic files:
The uprev process works similar to the File> Save Hierarchy process. The process visits each hierarchical block used in the design and uprevs them to the 16.5 release. The process is quite fast.
The following steps will guide you through the changes that occur when you uprev your design to the 16.5 release.
1. Open an existing design in 16.5 release. The tool auto detects that the design is a pre-16.5 release design and prompts you to uprev the design with the following message dialog:
2. Click 'Yes' to start upreving the design. The process iterates over all the hierarchical blocks which have been used in the design and uprevs all the blocks to the 16.5 release.
Note: If there are errors during uprev, check the temp/csnetlister.mkr file for leads.
I look forward to your comments on DEHDL 16.5 upreving.
Jerry "GenPart" Grzenia
