• Home
  • Community
  • Blogs
  • PCB Design
  • Why Move Up to Allegro 17.2-2016? New Concurrent Team Design…
PCB Design Blogs
  • All Blog Categories
  • Breakfast Bytes
  • Cadence Academic Network
  • Cadence Support
  • Computational Fluid Dynamics
  • CFD(数値流体力学)
  • 中文技术专区
  • Custom IC Design
  • カスタムIC/ミックスシグナル
  • 定制IC芯片设计
  • Digital Implementation
  • Functional Verification
  • IC Packaging and SiP Design
  • In-Design Analysis
    • Electromagnetic Analysis
    • Thermal Analysis
    • Signal and Power Integrity Analysis
    • RF/Microwave Design and Analysis
  • Life at Cadence
  • Mixed-Signal Design
  • PCB Design
  • PCB設計/ICパッケージ設計
  • PCB、IC封装:设计与仿真分析
  • PCB解析/ICパッケージ解析
  • RF Design
  • RF /マイクロ波設計
  • Silicon Signoff
  • Solutions
  • Spotlight Taiwan
  • Tensilica and Design IP
  • The India Circuit
  • Whiteboard Wednesdays
  • Archive
    • Cadence on the Beat
    • Industry Insights
    • Logic Design
    • Low Power
    • The Design Chronicles
mcatramb91
mcatramb91
6 Sep 2016
Why Move Up to Allegro 17.2-2016? New Concurrent Team Design Capability (Reason 2 of 10)
Use teamwork to get off the critical path!
When (not if) change happens or scope creeps... the PCB design team is always on the critical path. You can answer this schedule challenge by dynamically scaling resources with the new concurrent team design capabilities in the Allegro 17.2 2016 Release. We created this product offering to provide designers with a quick an easy way to share a common Allegro database to perform collaborative design activities to tackle today's design challenges. Whether a formal project team is formed or at a moment's notice, a designer can simply share their current design and invite other designers to join for assistance. You can also accelerate the project by letting your experts contribute by specialty.  With no added design management by copying databases around and cut/paste design updates into a master database, the new Allegro® PCB Symphony Team Design Option is a real-time collaborative environment using a single database that can be made available to the design team in minutes.
Solution One:  Think "24 x 7"
Ideal for distributing the work across multiple design locations, our original "asynchronous" Allegro PCB Team Design Option supports splitting the work into partitions of the design and merging the results into a master database.  The workflow manager provides partitioned section status and multidirectional communication features that encourage strong collaboration between designers.  Team members can view the work of others and easily address the shared areas between partitions using soft boundaries to work outside of partitions and create layer-based partitions.  The Merge Wizard automates steps involved with front-end netlist changes and automates the merge-import netlist-split process while resolving constraint conflicts.
Solution Two:  Think "Triple Team" (new for 17.2 2016)
Ideal for adding more team members in the same location, our new "synchronous" Allegro PCB Symphony Team Design Option supports real-time co-design.  By connecting users to a common Allegro PCB database, multiple designers can easily work on the design at the same time, and any changes made by one team member are seen in real-time by all members.  The initial release is focused on reducing the PCB design cycle time during the routing stages of the design that can account for up to 80% of the overall project schedule for dense, complex designs.  We provided support for component rearrangement including Reuse Module and Place Replica groups; interactive routing with dynamic shape/trace plowing; route finishing tools like Auto-Interactive Phase/Delay Tuning, Timing Vision and Custom Smooth; and even the ability to complete silkscreen and assembly cleanup.   All users’ modification will generate a temporary display of possible updates with visual "color-coded" canvas locks with each client having the ability to apply permanent locks on interfaces they are working on all to allow the team to work happily.
Save time, get ahead of schedule
Designers today spend the majority of their time during the routing phases of the design and have adopted the Auto-Interactive capabilities to accelerate routing and tuning.  Using the new Symphony Team Design Option in the Allegro 17.2-2016 release, will take it to a higher level with designers working together on the same design to complete the routing effort which can shorten routing time by up to 80% for dense and complex designs.
As always your comments are welcome!
What barriers have you faced bringing multiple PCB designers into one project?  What are your top three tips to share?  Please sign-in above and start contributing to the community discussion.
Related Webinar
Team Source Your PCB Layout - Hassle Free Real-Time Team Design
Related Videos
Symphony Team Design Demo Reel
Related Links
10 Top Reasons to Move Up to Allegro 17.2-2016 Release
Cadence® Allegro® Symphony Team Design
Cadence® Allegro® TimingVision™ Technology
Tags:
  • Allegro 17.2 |
  • Symphony |
  • Real Time Design |
  • PCB design |
  • Why Move Up to 17.2 |
