  3. Wild River Collaborates with Cadence on CMP-70 Channel …
MSATeam
MSATeam
test fixtures
channel modeling
signal integrity analysis
simulation to measurement
Signal Integrity
Clarity 3D Solver
Wild River Collaborates with Cadence on CMP-70 Channel Modeling
23 Oct 2024 • 2 minute read
 Wild River Technology (WRT), the leading supplier of signal integrity measurement and optimization test fixtures for high-speed channels at data rates of up to 224G, has announced the availability of a new advanced channel modeling solution that helps achieve extreme signal integrity design to 70GHz. Read the press release.
The CMP-70 program continues the industry-first simulation-to-measurement collaboration with Cadence that was initially established with the CMP-50. Significant resources were dedicated to the development of the CMP-70 by Cadence and WRT over almost three years. The CMP-70 will be on display at DesignCon 2025, January 28-30, in Cadence booth 827 to benchmark the Cadence Clarity 3D Solver.
“I am not a fan of hype-based programs that simply get attention,” remarked Alfred P. Neves, WRT’s co-founder and chief technical officer. “Both Cadence and Wild River brought substantial skills to the table in this project as we continued our industry-first simulation-to-measurement collaboration. The result is a proven, robust and accurate platform that brings extreme signal integrity to 70GHz designs. This application package has also been instrumental in demonstrating the robust 3D EM simulation capability of the Cadence Clarity solver.”
“We’re delighted to continue the joint development and validation program with WRT that started with the CMP-50,” said Gary Lytle, product management director at Cadence. “The skilled and experienced signal integrity technologists that both companies bring to the program results in a superior signal integrity solution for our mutual customers.”
CMP-70 Solution Features
The solution is available both in a standard configuration and as a custom solution for customer-specific stackups and fabrication. The primary target application is to support a 3D EM solver analysis modeling versus the time- and frequency-domain measurement methodologies. The solution features include:
  • The CMP-70 platform, assembled and 100% TDR NIST traceable tested, with custom stands
  • Material Identification overview web-based meeting including anisotropic 3D material identification
  • A cross-section PCB report and structures for using as-fabricated geometries
  • Measured S-parameters, pre-tested for quality (passivity/causality and resampled for time domain simulations)
  • A host of novel crosstalk structures suited for 112G HD level project analysis
  • PCB layout design files (NDA required)
  • An EDA starter library including loss models with industry-first accurate surface roughness models
  • Comprehensive training available for 3D EM analysis – correspondence, material ID in X-Y and Z axis for a host of EDA tools
Industry-First Hausdorff Technique
1 Application of modified Hausdorff techniqueThe WRT application package also includes an industry-first modified Hausdorff (MHD) technique, included as MATLAB code. This algorithmic approach provides an accurate way to compare two sets of measurements in multi-dimensional space to determine how well they match. The technique is used to compare the results simulated by the Clarity solver with those measured on the CMP-70 platform. The methodology and initial results are shown in the figure below, where the figure of merit (FOM) is calculated from 10, 35, and finally to 50GHz. The MHD algorithm requires a MATLAB license, but WRT also accommodates customer data as another option, where WRT provides the comparison between measured and simulated data.
Additional Resources
  • If you are attending DesignCon 2025, be sure to stop by Cadence booth 827 to see WRT’s CMP-70 advanced channel modeling solution in action with the Clarity 3D Solver.
  • Check out our on-demand webinar, "Validating Clarity 3D Solver Accuracy Through Measurement Correlation."
  • Learn more about the CMP-70 solution and the Clarity 3D Solver.
  • For more information about Cadence’s full suite of integrated multiphysics simulation solutions, download our Multiphysics System Analysis Solutions Portfolio.
