  2. RF Engineering
  3. μWaveRiders: New Python Library Provides a Higher-Level…
TeamAWR
TeamAWR
RF Simulation
Circuit simulation
AWR Design Environment
Python
API
pyawr utilities
awr
RF design
VBA
microwave office
Visual System Simulator (VSS)
scripting
μWaveRiders: New Python Library Provides a Higher-Level API in the Cadence AWR Design Environment
18 Jul 2022 • 5 minute read
Team RF logoThe Team RF "μWaveRiders" blog series is a showcase for Cadence AWR RF products. Monthly topics will vary between Cadence AWR Design Environment release highlights, feature videos and spotlights, and software tips, tricks, and customization. Subscribe to receive email notifications about our latest μWaveRiders blog posts.
Introducing Python Scripting Utilities for the AWR Design Environment
In the series μWaveRiders: Scripting in the Cadence AWR Design Environment blog, the use of scripting for automating repetitious commands as well as for post processing of simulated data was highlighted. The two main scripting languages in use are a language based on Visual Basic for Applications (VBA) and Python. One key enhancement mentioned in the blog related to the use of Python as a scripting language for AWR Design Environment software is the introduction of the pyawr library. This library wraps a number of lower level functions into a higher level interface between Python and the AWR software. Code completion is another key contribution of the pyawr library.
Using the pyawr library alone still requires that you reference API commands and API documentation written for VBA. A new Python library has been introduced that works in conjunction with the pyawr library to provide an even higher level API that provides commands that are oriented more towards Python syntax.
Challenges with the AWR API in Python
The AWR Design Environment API is an exhaustive set of commands for nearly every function that can be manually performed through the user interface. The API has a legacy formed around VBA, however, so Python programmers must convert the VBA-oriented syntax into Python-compatible commands. All of the code examples in the API documentation use VBA, which forces Python programmers to learn enough about the VBA structure and syntax to interpret the commands.
Many of the API commands do not follow Python coding conventions. In other words, the API is not “pythonic.” Among the non-pythonic issues of the API commands is array indexing that begins with one, not zero. This indexing is also not consistent in that some commands can use zero-based indexing, while others require one-based indexing. Another example of non-pythonic programming style stems from the lack of lists and dictionaries for data structures.
API commands used in the Python environment lack robust error trapping mechanisms and error messages tailored towards Python. Debugging to root cause can be a difficult and time-consuming process.
Arguably the biggest issue with using the API is the time spent looking up each command in the documentation. This is in addition to the time it takes to interpret the VBA-based command structure into a Python-compatible format. The API is organized around a VBA perspective that uses collection of objects. To use the listing of commands in the API documentation, you must be familiar with how VBA fundamentally uses collection of objects. This structure is not intuitive for the Python programmer.
Introducing pyawr-utils
A new Python library has been written to facilitate an interface between Python and AWR software using a command structure that adheres more closely to Python coding conventions. This library is labeled pyawr-utils and it is installed using the standard Python pip command. Comprehensive documentation for installing and using pyawr-utils is available.
Many of the challenges with the existing API are addressed when using the pyawr-utils, which offer:
  • Coding conventions more oriented towards Python, including collections of objects that are returned as either lists or dictionaries.
  • Consistent use of zero-based indexing of lists and arrays.
  • API document organization that is more functionally-oriented than alphabetically-oriented. For example, commands related to elements are organized under the Schematics section, and measurement-related commands are organized under the Graph section.
  • More robust error checking for Python and API syntax.
  • More robust error checking when illegal AWR Design Environment commands are attempted (for instance when trying to access a document or measurement that does not exist).
  • Error commands that are more descriptive for the Python environment, allowing more efficient debugging.
Additionally, the pyawr-utils documentation includes code examples written in Python. Not only does this remove the time-consuming and error-prone process of interpreting the VBA-based documentation into Python, but it allows for direct copy and paste of the Python code into the Python development environment.
pyawr_utils chart
Resources for pyawr-utils
There is a growing body of complete code examples using the pyawr-utils library.
The initial version of pyawr-utils includes commands for circuit schematics, system diagrams, elements, equations, graphing, and data files. Future enhancements will include commands for layout, EM structures, optimization, yield analysis, and more.
By: Brian Avenell  (Sr. Principal Product Engineer) and David Webster (Lead Product Engineer)
Cadence AWR R&D - U.S.
Blogs
  • μWaveRiders: Scripting in the Cadence AWR Design Environment
  • μWaveRiders: Cadence AWR Design Environment Graph Measurements Tips and Tricks
  • μWaveRiders: Cadence AWR Design Environment Graph Display Tips and Tricks
  • μWaveRiders: Cadence Microwave Office Layout Tips and Tricks
  • μWaveRiders: Cadence AWR Design Environment Advanced Customization Tips & Tricks
  • μWaveRiders: Cadence AWR Design Environment Customization Tips & Tricks
  • μWaveRiders: Cadence AWR Design Environment Schematic/System Diagram Tips & Tricks
  • μWaveRiders: Cadence AWR Design Environment/Project Browser Tips & Tricks
  • μWaveRiders: Cadence AWR Design Environment Project Management Tips and Tricks
Examples
  • pyawr Utilities Examples
Documentation
  • pyawr-utils Documentation
