  2. AutoMesh
  3. Seed point is too close to one of the geometry boundaries...
  • State Verified Answer
  • Subscribers 6
  • Views 6356
Colinda
Colinda over 4 years ago
When I generate a mesh, a warning appears that indicates that the seed point is too close to one of the geometry boundaries. Is this expected? It looks like the mesh is good.
  • Colinda
    Colinda over 4 years ago +1 verified
    This warning always appears when the seed point is close to a wall. This warning only has a meaning if you obtain an "empty mesh" as result. As you get a mesh, you can continue without any doubts and ignore…
  • Colinda
    +1 Colinda over 4 years ago
    This warning always appears when the seed point is close to a wall. This warning only has a meaning if you obtain an "empty mesh" as result. As you get a mesh, you can continue without any doubts and ignore this warning.
