  2. AutoMesh
  3. 3D mesh generation failed. Could not create fillet geometry...
  • State Verified Answer
  • Subscribers 8
  • Views 4643
3D mesh generation failed. Could not create fillet geometry. Cannot create valid fillet lofted surfaces.
Hans Hager
Hans Hager over 3 years ago
I am using AutoGrid5 and I tried to mesh a turbine Blade (structured mesh, highly staggered, O4H)  with Butterfly fillet topology (Method: B2B section offset).
Unfortunately I get the following error message:
What could be the reason?
Hans
  • Gaurav
    Gaurav over 3 years ago +1 verified
    This post is related to "3D mesh generation failed. Could not create fillet geometry. No blend surfaces created". Please verify
  • Gaurav
    +1 Gaurav over 3 years ago
  • Hans Hager
    0 Hans Hager over 2 years ago in reply to Gaurav
    Yes, it is related.
    Can the solution be, that the second B2B plane has to have an offset from the first B2B plane at the hub, higher than the fillet radius?
    Regards
    Hans
