  2. AutoMesh
  3. Mastering Turbine Mark-II Meshing – A Step-by-Step Automation...
  • Subscribers 8
  • Views 2959
Mastering Turbine Mark-II Meshing – A Step-by-Step Automation Guide Using Fidelity Python API
Gaurav
Gaurav over 1 year ago
In this case study, we will be examining the meshing workflow process for a turbine nozzle guide vane, specifically the Mark II model. The primary objective is to demonstrate the capabilities of the Fidelity Python API script in accurately generating a mesh for a 2D high-pressure turbine blade. Through this example, we intend to illustrate how the API can efficiently manage complex meshing tasks, providing users with valuable insights into various key meshing parameters.
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1OPP000000sTWU2A2&pageName=ArticleContent
  • KBBKBB
    KBBKBB over 1 year ago
    Hi Gaurav,
    I just wanted to thank you for the great contributions you’ve made. Your detailed Python scripts and explanations are extremely helpful for understanding and automating workflows in Fidelity.
    I really appreciate the time and effort you put into sharing your knowledge. Keep up the good work!
    Best regards
  • Gaurav
    Gaurav over 1 year ago in reply to KBBKBB
    Thanks KBBKBB
