  2. AutoMesh
  3. flip a gemotry in Autogrid
  • Subscribers 8
  • Views 489
sima101f
sima101f 2 months ago
HI ,
i would like to know how to flip a geomtery in  Autogrid. I currently have gemturbofile and want to flip it so that after flipping pressure side becomes suction and vice versa ? can someone please guide
Sid
TU Dresden
  • Gaurav
    0 Gaurav 2 months ago
    Hello, you can locate the Flip option in the geometry section of the software.
    This feature allows users to switch the face orientation of geometry in Fidelity.
    Steps:
    Click on the Rendering options widget on the toolbar.
    Change the Draw mode option to Orientation.
    Exit the tool.
    On the 3D view, select the entities to change the face orientation.
    Right-click on the selected entities.
    Select the Flip orientation option.
    Limitation
    If there are different face orientations in the view, it is not possible to set all front or back faces in a single click using this feature.
  • sima101f
    0 sima101f 2 months ago in reply to Gaurav
    Thank you very much for your response.
    Could you please tell that in Autogrid enviornment? unfortunately I not fimiliar with Fidelity.
    Thank you
    Sid
    TU Dresden
  • Gaurav
    0 Gaurav 2 months ago in reply to sima101f
    At this time, mirroring geometry is not available in Autogrid. However, users can easily achieve this by opening the same geometry in IGG, where the mirroring feature is accessible.
