  2. Flow
  3. Questions regarding OMNIS
  • State Verified Answer
  • Subscribers 8
  • Views 4350
Durai12
Durai12 over 3 years ago
I have two queries and would greatly appreciate it if they could be answered:
1) Is there any tutorial for 2D simulations in OMNIS? Specifically 2D airfoil simulation
2) When I try to save my project, I get an error saying " Warning, unable to create directory". Any ideas on how to solve it?
Thanks in advance.
  • BIPal
    BIPal over 3 years ago +1 verified
    Hello, 1. There are no 2D tutorials available at the moment. Omnis solvers are 3d. What you can do is create a domain as thin as possible in the third dimension (3 cells minimum). 2. Could you please…
  • BIPal
    +1 BIPal over 3 years ago
    1. There are no 2D tutorials available at the moment. OmnisTm solvers are 3d. What you can do is create a domain as thin as possible in the third dimension (3 cells minimum).
    2. Could you please clarify:
    • What OS are you using?
    • What Omnis version are you using?
    • How are you starting Omnis?
    • Where is it installed?
    • Are you able to create a folder in the save directory outside of Omnis?
    • Do you have enough disk space available?
    • Do you have permission to save in the target directory?
    Thanks!
