  2. Flow
  3. Fidelity Split along an ISO curve on primitives
  • State Verified Answer
  • Subscribers 7
  • Views 3956
nopech
nopech over 3 years ago
Hello everyone
Since Interfaces have to consist of at least 2 patches, i have to cut my patch. Fidelity has this tool called "Split along an ISO curve" but it keeps finding excuses for not working. For example it is not working on primitives. Any alternatives? Maybe convert the primitive to non-primitive within Fidelity?
Thanks!
  • BIPal
    BIPal over 3 years ago +1 verified
    Hello, Have you tried performing a boolean subtract ? This should be possible with a plane as the tool body and solid as the target body. Best regards, Botond
  • BIPal
    +1 BIPal over 3 years ago
    Have you tried performing a boolean subtract? This should be possible with a plane as the tool body and solid as the target body.
    Best regards,
    Botond
  • nopech
    0 nopech over 3 years ago in reply to BIPal
    Hi Botond
    Thanks for your suggestion, boolean subtract does work.
    For the records, an alternative would also be to export the primitive as parasolid and then import again. A button to convert to primitive to cad would be nice...
