  2. Flow
  3. Crash - Solver
  • State Verified Answer
  • Subscribers 7
  • Views 7928
Crash - Solver
TobiasB
TobiasB over 2 years ago
Hello
Im am new to using FineMarine, and during the tutorials (Tutorial 5 - planning) i am having some trouble with the solver.
I dont seem to be able to upload a picture of the crash-report directly from my pc, however it says:
RUN INFO:
Pre-processing: Finished
Solver: Crashed
Post-Processing: Finished
Thanks in advance!
  • Colinda
    Colinda over 2 years ago +1
    Hi Tobias, Could you please provide more information: Which Fine Marine version are you using? On which OS are you running? If you are running in parallel: does it work in serial? The number…
  • TobiasB
    TobiasB over 2 years ago in reply to Colinda +1
    - Hotfix 12.10.004 - Windows 10 And it seems to be the core problem... i just enabled the cores i had available on my pc Thanks for the help
  • Colinda
    Colinda over 2 years ago in reply to TobiasB +1 verified
    Hi Tobias, First we need to make sure the ISIS-CFD license server can be found and the needed features are available. Could you please go to the Admin Tool and check under License management the License…
  • Colinda
    0 Colinda over 2 years ago
    Hi Tobias,
    • Which Fine Marine version are you using?
    • On which OS are you running?
    • If you are running in parallel: does it work in serial? The number of cores you are using is allowed by the license you have? For example, the individual student license runs on up to 4 cores.
    • Can you open the .std file in the computation folder (there is also a button to open it in the Task Manager)? At the end of the file should be more information about the reason of the solver crash.
  • TobiasB
    0 TobiasB over 2 years ago in reply to Colinda
    - Hotfix 12.10.004
    - Windows 10
    Thanks for the help
  • TobiasB
    I tried running with 4 cores although still a crash
    Checking the std i seem to spot a few problems:
    MESH (T) : File not specified
    VELOCITY (T) : File not specified
    PSEUDO-VELOCITY (T) : File not specified
    MOBILE FRAME VELOCITY (T) : File not specified
    PRESSURE (T) : File not specified
    HYDRODYNAMIC PRESSURE (T) : File not specified
    VELOCITY FLUXES (T) : File not specified
    VORTICITY (T) : File not specified
    WALL SHEAR STRESS : File not specified
    INVARIANT DE (T) : File not specified
    SECOND INVARIANT (T) : File not specified
    HELICITY (T) : File not specified
    COURANT NUMBER (T) : File not specified
    VEL. GRAD. (U) (T) : File not specified
    VEL. GRAD. (V) (T) : File not specified
    VEL. GRAD. (W) (T) : File not specified
    PRESSURE GRAD. (T) : File not specified
    U VEL. RESIDUAL (T) : File not specified
    V VEL. RESIDUAL (T) : File not specified
    W VEL. RESIDUAL (T) : File not specified
    PRES. RESIDUAL (T) : File not specified
    VOLUME FRACT. (T) : File not specified
    VOL. MASS (T) : File not specified
    TURB. DYN. VISC. (T) : File not specified
    TURB. KIN. EN. (T) : File not specified
    TURB. KIN. EN. GRAD. (T) : File not specified
    TURB KIN EN RES. (T) : File not specified
    TURB. FREQ. (T) : File not specified
    TURB. FREQ. GRAD.(T) : File not specified
    TURB. FREQ. RES. (T) : File not specified
    CORRELATION R11 (T) : File not specified
    CORRELATION R12 (T) : File not specified
    CORRELATION R13 (T) : File not specified
    CORRELATION R22 (T) : File not specified
    CORRELATION R23 (T) : File not specified
    CORRELATION R33 (T) : File not specified
    TURB. DISS. (T) : File not specified
    OTHER FILES
    CONVERGENCE : E:\FineMarine\Direction\Projects\PlanningTUT2/PlanningTUT2_C1_7.000ms/PlanningTUT2_C1_7.000ms.res
    NEWTON'S LAW CONVERGENCE : E:\FineMarine\Direction\Projects\PlanningTUT2/PlanningTUT2_C1_7.000ms/PlanningTUT2_C1_7.000ms.res_mvt
    NORMAL TO THE WALLS DATAFILE : E:\FineMarine\Direction\Projects\PlanningTUT2/PlanningTUT2_C1_7.000ms/b001/feet.cpr
    MIN(DISTANCES) TO THE WALLS : -
    PROBES
    SURFACE PROBE TYPE : WALL
    PROBE VARIABLE : LOCAL FORCES
    RELATED FILE : E:\FineMarine\Direction\Projects\PlanningTUT2/PlanningTUT2_C1_7.000ms/b001/wall_data.cpr
    TEMPORAL PERIOD OF PROBING : 0.0000000E+00
    AVERAGE QUANTITIES
    Unable to locate ISIS-CFD license server
    or all ISIS-CFD licenses are checked out.
    Fail to check out isiscfd license.
    ! All parallel processes stopped by block 1
    Abort(1) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
    mainly all the unspecified values and the "unable to locate ISIS-CFD license" i dont know if this might be the problem
  • Colinda
    +1 Colinda over 2 years ago in reply to TobiasB
    Hi Tobias,
    Could you please go to the Admin Tool and check under License management the License server tab?
    Does it show the licenses server as up and running?
    When you double-click on the server name, does it show the features isiscfd and isismpi to be available?
    The Diagnostics in the Admin Tool may also give you more info about the license server.
    Please make sure that you selected both license files at the same time when activating the license.
    Best regards,
    Colinda
  • TobiasB
    Hi
    Through some trial and error i got it running (so far without crashing)
    I suppose it did not properly autostart the solver license after reboot.
    However the solver has been running for around 30 minutes by now
