  2. Flow
  3. customized gaps
  • Subscribers 8
  • Views 2685
customized gaps
WS202410062051
WS202410062051 over 2 years ago
If you select the .dat file in the defined shape, how should you write the face you want to use in this file, which is the format in the .dat file?
  • Gaurav
    0 Gaurav over 2 years ago
    You can visit support.cadence.com to find the IGG User manual and refer to Chapter 12 for instructions on writing the .dat file.
    Please review Chapter 6, "Hub/Shroud Partial Gaps Control," in the "AutoGrid5" user guide manual. Additional information about the "Defined Shape" can be found, and for the .dat format, details are available in the "Curve data files of Igg User Manual."
