  2. Flow
  3. Need help on modeling of Realizable k-epsilon turbulence...
  • Subscribers 8
  • Views 2566
Need help on modeling of Realizable k-epsilon turbulence viscosity
AL202410221044
AL202410221044 over 1 year ago
Dear community,
I am having a question that need your help reading the modeling of Realizable k-epsilon turbulent viscosity.
In this model, CMU is varied instead of a constant value as in the standard model. In that, some additional equations is used for calculate the CMU, including:
U*=sqrt(Sij*Sij+Ωij*Ωij)
Ωij= 0.5*(∂ui/∂xj  - ∂uj/∂xi )
Sij= 0.5*(∂ui/∂xj  + ∂uj/∂xi )
and
W=Sij*Sjk*Ski/Š3
S=sqrt(Sij*Sij)
I wonder for the two-dimensional (2D) simulation, the U* and W will be expressed as follows???
U* = sqrt(S11*S11+S22*S22+2*S12*S12+2*Ω12*Ω12)
W = (S11^3+S22^3+3*S12^2*(S11+S22))/S^3
with S=sqrt(S11*S11+S22*S22+2*S12*S12)
Thank you for your help.
  • Gaurav
    0 Gaurav over 1 year ago
    The decomposition of U* and W appears accurate for 2D flow. Which software are you using, Fidelity or Fine Products?
