  2. Flow
  3. Simplifying simulation cloning with Python scripting
  • Subscribers 10
  • Views 3516
Gaurav
Gaurav over 1 year ago
Optimized for Fidelity 2024.2, this script offers a seamless simulation setup experience. It provides an automated guide to duplicate simulations. Parametric studies are facilitated through boundary condition modification. Utilizing Fidelity Python functions, the setup is streamlined.
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1OPP000001DsBh2AK&pageName=ArticleContent
  • KBBKBB
    KBBKBB over 1 year ago
    Thanks for the insights, Gaurav!
    Unfortunately, I’m a bit confused about these two lines:
    Why is this being done again?
    Also, as you can see, the word "type" is highlighted differently. I looked it up and found that it can be used either as a function or as a metaclass (whatever taht means).
    On top of that, the get_initial_solution_choice() function returns a string — specifically, one of the following: 'Constant values', 'Turbo', 'Techno effects', or 'From solution'.  What do we need that for? "Type" and "dom_params" are not used afterwards in the code.
    So I’m a bit lost here.
  • Gaurav
    Gaurav over 1 year ago in reply to KBBKBB
    Hello KBB,
    In this computational domain, it can be observed that the plugins for "hexpress_parameters" are required. However, the function associated with "from Solution" is not defined under the "hexpress_parameters" module. Consequently, the module "euranus_parameters" is utilized instead.
    The "euranus_parameters" module is specifically designed for turbo applications. It is assumed that the development team will define the "from_solution" functionality for both modules in future versions.
  • KD202502275710
    KD202502275710 over 1 year ago
    This is indeed awesome. Very helpful
