  2. Flow
  3. Francis Turbine Workflow: Geometry to Results Analysis with...
  • Subscribers 7
  • Views 1330
Francis Turbine Workflow: Geometry to Results Analysis with Fidelity
Gaurav
Gaurav over 1 year ago
Are you looking to streamline your simulation setup process and unlock the full potential of Python scripts?  This RAK (Rapid Adoption Kit) is designed to make your simulation experience smoother, more efficient, and more effective.
Benefits of Using RAK:
Rapid Setup: With RAK, you can quickly and easily set up several powerful Fidelity modules, ensuring a seamless experience from the start.
Comprehensive Module Integration: The script utilizes a range of modules, including project, GUI, geometry, domain setup, meshing, grid creation, material properties, simulation, and analysis. These modules work together perfectly, making it easy to establish your simulation environment.
Easy Integration with Fidelity Plugins: The Euranus parameters module allows you to effortlessly integrate Python functions into your simulation and meshing workflows.
The GAMM turbine, a specific model of the Francis hydraulic turbine, has been used as a test case in the 1989 GAMM workshop. This model is widely used in power generation and has been extensively tested in laboratory settings. With RAK, you can easily set up and simulate this model, and many others like it.
Don't miss out on the opportunity to take your simulations to the next level. Try RAK today and experience the power of streamlined simulation setup
