  2. Installation
  3. Problem after the solver crushing in Fine Marine
  • State Verified Answer
  • Subscribers 6
  • Views 5695
AhmedTaha
AhmedTaha over 3 years ago
Hello
I faced an issue after my last simulation the solver crashed, and Fine Marine closed, once I restart the application it shows a white picture as the photo below, then it closed.
this issue just occurred with fine marine only, HEXPRESS is working fine.
Info : Using USERPROFILE Env.Var.: C:\Users\Ahmed WS\ user name is Ahmed WS
Info : AppData is C:\Users\Ahmed WS\AppData\Roaming
<***> FINE/MARINE 10.2-2 - Dec 17 2021
NIBCDataBase::clear lists
NIBCDataBase::read:
Checking license for FINE/Marine ...
License file format is too old, Please check that it contains the ISSUER field.
OK.
Info: this is an 'academic' license.
Checking available features for FINE/MARINE:
-> BASIC feature is available.
-> FSI: MODAL feature is available.
-> C-WIZARD feature is available.
Using Parasolid V32.1.222
PYTHONHOME = C:\NUMECA_SOFTWARE\FineMarine102_2\python64
Main window geometry: 1080x800
HDriver
type : WGL_Hardware
version : 2.345.2.3
planes : 24
colors : 16777216
max colors : 16777216
z buffer depth : 24
hard cutting planes: 8
hard lights : 8
hard gouraud : yes
hard phong : yes
width : 1.02999997138977 cm
height : 101.980003356934 cm
aspect ratio : 0.0100999996066093
max width : 51.7999992370605 cm
max height : 32.3800010681152 cm
width resolution : 37.0660018920898 px/cm
height resolution : 37.0660018920898 px/cm
Check ITS license: 0
Starting pvmd with argument '-nAhmed-WS'...
Pvmd is already running.
  • AhmedTaha
    AhmedTaha over 3 years ago in reply to Colinda +1 verified
    Hi, Please note that I resolve the issue by removing tmp files from my user folder, I think the cache was full and this prevented the launch. Best regards, Ahmed
  • Colinda
    0 Colinda over 3 years ago
    Could you please launch Fine Marine from a command prompt with the -print argument and see in the shell whether there is additional information?
    Best regards,
    Colinda
  • AhmedTaha
    +1 AhmedTaha over 3 years ago in reply to Colinda
    Best regards,
    Ahmed
