  2. Marine
  3. Restart of a simulation.
  • State Verified Answer
  • Subscribers 6
  • Views 4948
Colinda
Colinda over 4 years ago
How to restart a computation?
  • Colinda
    Colinda over 4 years ago +1 verified
    There are several common scenarios that require restarting a simulation: when it has stopped unexpectedly, when it should run longer than initially foreseen or to assess more or different physics compared…
  • Colinda
    +1 Colinda over 4 years ago
    There are several common scenarios that require restarting a simulation: when it has stopped unexpectedly, when it should run longer than initially foreseen or to assess more or different physics compared to the on-going simulation.
    The workflow is the following:
    1. Select the computation to restart in the list of computations.
    2. Use the New button to create a new computation: all settings will be copied from the first computation.
    3. In the Initial solution menu, activate the button Restart from previous computation. The possible computations to restart from are available in a drop-down list.
    1. In the Control variables menu, adjust the Number of time steps to the value needed in this second computation.
