  2. Marine
  3. 2D simulations of hydrofoil profiles
  • State Verified Answer
  • Replies 7
  • Subscribers 7
  • Views 10736
rodb
rodb over 3 years ago
Hello to everyone,
I should perform 2D multi-fluid simulations of NACA profiles used for hydrofoils and study the variation of Cl and Cd at different dives (distance from the sea surface), is it possible to do it with Fine Marine or do you recommend Omnis?
thank you,
R
  • Benoit Mallol
    Benoit Mallol over 3 years ago in reply to rodb +1 verified
    Yes, absolutely: Tutorial 3 - Advanced - is a 2D case of a falling prism and Democase 2 is also 2D for a rolling decay test. They should be a good starting point to know how to manipulate 2D projects…
  • Benoit Mallol
    Hello, great to hear you managed to get good results with a round leading edge! For a sharp one, I see there are two items in your message: 1) solver divergence and 2) viscous layers insertion if I…
  • rodb
    rodb over 3 years ago in reply to Benoit Mallol +1
    Hello, sorry for my late reply, I ran some test simulations, saving the results more frequently, in this way, as you advised me, I evaluated the points where the pressure and speed (so also the turbulent…
  • Benoit Mallol
    0 Benoit Mallol over 3 years ago
    Fine Marine is definitely the software of choice here! :-)
    Best regards,
    Benoit
  • rodb
    0 rodb over 3 years ago in reply to Benoit Mallol
    Thank you,
    there is some documentation about 2d simulation in fine marine? or maybe tutorials? all I find is for 3D simulations...
    Best regards,
    R
  • Benoit Mallol
    +1 Benoit Mallol over 3 years ago in reply to rodb
    They should be a good starting point to know how to manipulate 2D projects.
    Last point: if you go directly to the HEXPRESS documentation, you can find a documentation page: HEXPRESS > User Guide > Mesh Wizard > 2D/3D Mesh Generation. It gives several details about 2D case preparation.
    Best regards,
    Benoit
  • rodb
    thanks for the answer, I was able to get very good results by simulating NACA profiles with a round leading edge.
    I am trying to simulate profiles with a sharp leading edge for high Reynolds numbers (10^6 - 10^7), unfortunately, however, the residuals are always very high and only through HEXPRESS I cannot thicken the mesh adequately. Is there anything I can do?
    thank you
    R
  • Benoit Mallol
    For a sharp one, I see there are two items in your message: 1) solver divergence and 2) viscous layers insertion if I understood correctly.
    For 1), the best is to save the solution before it diverges and check where the pressure/velocity spots are coming from. This advice comes from the FAQ here: "FINETm/Marine > FAQ > My calculation stopped abnormally. How can I manage?" Maybe the check list could also help. If you are still in 2D, you should check the mesh quality and also the tessellation itself.
    For 2), what is your problem precisely? are you inserting viscous layers with inflation method and you observed a relatively low height compared to expectation?
    Best regards,
    Benoit
