  2. Marine
  3. Problem in Fine Marine Solver
  • State Verified Answer
  • Subscribers 7
  • Views 4161
Sakinah
Sakinah over 3 years ago
Hi and good day Sir/Madam,
I am using Fine Marine to evaluate resistance, my problem is when I am running the simulation the solver keep crash, here i attach a picture so you can take a look. Hope i can here the solution from your team.
Thankyou in advance.
https://www.linkpicture.com/view.php?img=LPic63c37b4704a501541605414
  • Benoit Mallol
    Benoit Mallol over 3 years ago +1 verified
    Hi, can you show the error message written in the .std file of the simulation? Just press the button: "Click here to open the .std file of the flow solver" and look for the error message. thanks a…
  • Colinda
    0 Colinda over 3 years ago
    I moved your question from the installation to the Marine section as it is about a crash for the Marine solver. Did you have a look in the standard output file (.std) as suggested in the pop-up window? It would be good to have a look at the end of the file where the simulation stopped. Did it run some iterations or did it already stop at the initialization?
    Best regards,
    Colinda
  • Benoit Mallol
    +1 Benoit Mallol over 3 years ago
    thanks a lot.
    Benoit
