  2. Marine
  3. trim condition
  • State Verified Answer
  • Subscribers 6
  • Views 9633
trim condition
saji vf
saji vf over 2 years ago
Hello , can we know where to specify forward and aft trim in fine marine, because we are only specifying free surface at even keel condition , can i know how to give the input.
Thank you.
  • Etienne F
    Etienne F over 2 years ago in reply to saji vf +1 verified
    Hi, There is no option directly available from the "resistance mode" of the C-Wizard to input the vessel trim. If you want to compute at a specific trim value, it is better to apply this trim to your…
  • Etienne F
    0 Etienne F over 2 years ago
    If you are speaking about the "planing regime" mode of the C-Wizard, you are able to impose a user-defined trim angle to your vessel in "Body configuration" section of the C-Wizard execution (i.e. the second graphical window appearing when executing the C-Wizard) . At the bottom of this graphical window, you have a menu named "Final position estimation" and there you can impose a user-defined trim angle. Note that the value should be entered relatively to the ship in its initial hydrostatic position and the rotation center used to apply the trim is the Center of Gravity defined in hydrostatic position (before applying the sinkage).
    Best regards,
    Etienne
  • saji vf
    0 saji vf over 2 years ago in reply to Etienne F
    Hello my question is about displacement vessel not planing hulls , because when we do the simulation here we consider Ta (aft trim) , Tf (forward trim) so can u tell me where to specify in resistance case.
  • Etienne F
    +1 Etienne F over 2 years ago in reply to saji vf
    There is no option directly available from the "resistance mode" of the C-Wizard to input the vessel trim. If you want to compute at a specific trim value, it is better to apply this trim to your geometry and to import the trimmed model in the C-Wizard. Another possibility would be to define both the center of gravity and the body mass as "user-defined" and to define the option "Adjust pitch for hydrostatic equilibrium ?" on "Free". Doing this, the trim of the ship will be adjusted to its hydrostatic position, before meshing the vessel. This second approach corresponds to the definition of the CoG which corresponds to the desired trim.
    Best regards,
    Etienne
  • saji vf
    Thank you for the info , is there any other way to specify it manually in the solver part?
  • Etienne F
    0 Etienne F over 2 years ago in reply to saji vf
    Appart from those mentioned above, there is no other possibilities that will help you to impose a trim from the solver part.
