  2. Marine
  3. maneuvering
  • State Verified Answer
  • Subscribers 6
  • Views 5719
maneuvering
saji vf
saji vf over 2 years ago
im trying to do static drift case condition,
1. in tutorials it was saying tx imposed with acceleration ramp and ty imposed with drift angle, but my doubt is how should we imply drift angle.
2. can you please share the formulae for implying drift angle and should we give the value deg or radians.
Thank you
  • Benoit Mallol
    Benoit Mallol over 2 years ago in reply to saji vf +1 verified
    Oh I see, thanks. In that case, what we propose is the following: for a static drift, the ship does not have to rotate around its gravity center. However, it is moving in X and Y directions. That's the…
  • Benoit Mallol
    0 Benoit Mallol over 2 years ago
    Just to be sure: which tutorial are you referring to? Maybe it is the democase 7 of the catamaran?
    Best regards,
    Benoit
  • saji vf
    0 saji vf over 2 years ago in reply to Benoit Mallol
    no we are following the best practices of maneuvering captive model test (not the catamaran drift) can you guide me how to do.
  • Benoit Mallol
    +1 Benoit Mallol over 2 years ago in reply to saji vf
    Oh I see, thanks.
    In that case, what we propose is the following: for a static drift, the ship does not have to rotate around its gravity center. However, it is moving in X and Y directions. That's the way to impose an angle with the flow.
    In terms of values, you should not impose an angle such as degree or radian but knowing the angle with the flow and the speed in X direction, you can compute the required velocity in Y direction, that will be imposed through Ty.
    You can impose the same ramp duration for both Tx and Ty.
    I hope I was clear enough.
    Best regards,
