  2. Online CFD Course
  3. Module 1: Simulation produces error: Mass is not a numb...
  • State Verified Answer
  • Replies 10
  • Subscribers 11
  • Views 14093
Module 1: Simulation produces error: Mass is not a number
SimonGohle
SimonGohle over 3 years ago
The problem I have with the first challenge might be a problem with my PC. When ever I start the simulation of the in the handout specified numbers, the simulation ends after some time and gives out the error message
 - S_Simulation 1 Error: ERROR: residual of Mass is Not A Number: the solver has been stopped
and the message
 - The simulation Simulation 1 has failed: some NaN have been detected during the computation.<br> ERROR: residual of Mass is Not A Number: the solver has been stopped
I don´t know if my PC´s CPU is maybe not good enough or if there might be a problem with my pre-processing in this challenge.
What worked is to set the CFL Number to 1.5 instead of 3.0, but the challenge requires running the simulation with a CFL of 3.0.
  • SimonGohle
    SimonGohle over 3 years ago in reply to SimonGohle +2 verified
    I found my error. There is a tab in the mesharea exactly looking the same for the viscos layers. Instead of setting it up in at the wall I set it up in the mesh set up in the tab local. That producet the…
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to LukasOde +2 verified
    Hi Lukas, to my understaning Simon has set up viscous layers not only on the walls but also on inlet and outlet because he used the "local" tab in the mehs setup. Please try the following: Select…
  • Manuel NIB
    Hi Lukas, thank you for your feedback! In class 1 we explained already that a simulation can converge and diverge. In all other classes we will quite often address potential divergence issues as the…
  • Kathrin
    0 Kathrin over 3 years ago
    Hi Simon,
    I assume you are using Omnis v5.2? Good news is: this problem does not originate from your CPU! This is what we call a diverging/crashing simulation. You did the proof yourself: By setting CFL to 1 the simulation does not converge anymore. Please try the following: Set the CFL to 3 and the CFL number (for CGI) to 1 as shown in the screenshot below.
    IF you are in essential mode, you just see the CFL number, which shall be put to 3. We were assuming that you would remain in essential mode.
    Could you please check if that solves the problem and give us a quick feedback? If that helps we would quickly update the hand-out.
    Best regards,
    Kathrin
  • SimonGohle
    0 SimonGohle over 3 years ago in reply to Kathrin
    Yes, I am using Omnis v5.2 . It is the other way around, if I set the CFL number on 3.0 it will produce the error, but if I set it on 1.5 it works. I looked into the program and CFL number is at 3 and CFL number (for CGI) is already at 1. I tried it also with lower speeds of 0.5 m/s, and then it worked fine with a CFL number of 3. So that is unfortunately not the solution I am searching
  • Kathrin
    0 Kathrin over 3 years ago in reply to SimonGohle
    I am trying to find out which solver setting might differ from the handout. So far I only get a crash of the simulation when I do not activate "Low speed flow".
    Could you please check if "Low speed flow (M>0.3)" is activated and the characteristic speed is set to 1.2m/s?
  • SimonGohle
    Yes, I have laminar Flow on and a tip at Low speeds with the correct velocity when the Error is produced.
  • SimonGohle
    0 SimonGohle over 3 years ago in reply to SimonGohle
    *And a tick at the low speeds not tip
