  2. Online CFD Course
  3. Error in CFD online course Elbow duct.
  • State Verified Answer
  • Replies 9
  • Subscribers 10
  • Views 10453
Rishi Shenoy
Rishi Shenoy over 3 years ago
Im using Omnis 5.2 software, as i simulate the elbow challenge im facing the error
<img src="qrc:/warning"/> The simulation Simulation 1 has finished but the convergence criterion cannot be reached.<br> Check your simulation settings and residuals.
and i tried many times changing the CFL number also still im facing the error and i couldn't complete the tast.
  • Manuel NIB
    Manuel NIB over 3 years ago +1 verified
    Hi Rishi, please note: This is "just" a warning and not an error. The message means that simulation reached the number of iteration without meeting the specified convergence criterion (see the screen…
  • Commodaro
    Commodaro over 3 years ago in reply to Rishi Shenoy +1 verified
    Hi, I've re-done the sim, and it converges with these parameters... when it failed to me, it might be that a value was wrongly entered due to the slowness I had on the connection to the computing machine…
  • Rishi Shenoy
    0 Rishi Shenoy over 3 years ago in reply to Manuel NIB
    This is the setting as per the handout, when i simulated this the result is not converging
  • Commodaro
    +1 Commodaro over 3 years ago in reply to Rishi Shenoy
    I've re-done the sim, and it converges with these parameters... when it failed to me, it might be that a value was wrongly entered due to the slowness I had on the connection to the computing machine. We will never know :-)
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Commodaro
    Hi Commodaro,
    thank you very much for letting us know!
    Best regards
    Manuel
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Rishi Shenoy
    Hi Rishi,
    thank you for these screen shots. I don't see a mistake. I think you missed the numerics tab. Just double check that my screen shot meets your settings:
    Please can you send me also a screen shot of your convergence history please. The rms residual of the density should look like for the non-extended case:
    Just to be sure: Are you working with Omnis v5.2 or are you maybe using 5.1?
    In case the settings look good I would recommend the following: Setup everything from scratch. It happened to users already that they changed a value in the simulation settings but did not run the simulation again. Later when they looked at the simulation they thought they ran it.
    Best regards
    Manuel
