  2. Online CFD Course
  3. Error in CFD online course Elbow duct.
  • State Verified Answer
  • Replies 9
  • Subscribers 10
  • Views 10198
Rishi Shenoy
Rishi Shenoy over 3 years ago
Im using Omnis 5.2 software, as i simulate the elbow challenge im facing the error
<img src="qrc:/warning"/> The simulation Simulation 1 has finished but the convergence criterion cannot be reached.<br> Check your simulation settings and residuals.
and i tried many times changing the CFL number also still im facing the error and i couldn't complete the tast.
  • Manuel NIB
    Manuel NIB over 3 years ago +1 verified
    Hi Rishi, please note: This is "just" a warning and not an error. The message means that simulation reached the number of iteration without meeting the specified convergence criterion (see the screen…
  • Commodaro
    Commodaro over 3 years ago in reply to Rishi Shenoy +1 verified
    Hi, I've re-done the sim, and it converges with these parameters... when it failed to me, it might be that a value was wrongly entered due to the slowness I had on the connection to the computing machine…
  • Manuel NIB
    +1 Manuel NIB over 3 years ago
    Hi Rishi,
    please note: This is "just" a warning and not an error. The message means that simulation reached the number of iteration without meeting the specified convergence criterion (see the screen shot below where you can specifiy these settings). In our everyday CFD projects we have this quite often and in most of the cases (if carefully cheked) the results are very reliable.
    Having said this, the case of challenge 2 should meet the convergence criterion. So it is very likely a setting in your setup differs from the values in the hand-out. So I would advise you to go through all the settings (once again). Please also check your mesh settings. Make in particular sure that the visous layers are only activated on the wall. Viscous layers should not be activated on inlet and outlet.
    Best regards
    Manuel
  • Rishi Shenoy
    0 Rishi Shenoy over 3 years ago in reply to Manuel NIB
    Thank you for the information, I get to know that my simulation result gets converges when i increased the iterartions otherwise the convergence criteria. so can you give some information on what we should change wheather it ts convergence criteria or iterations, Also one thing to add upon when i increased iterations it takes me much more time to compute so is there any way to accelerate the computation.
  • Commodaro
    0 Commodaro over 3 years ago in reply to Rishi Shenoy
    I had same issue, I re-checked all the values 3 times. Then I noticed I entered the Inlet velocity as 10 m/s and not 10.0 m/s
    I therefore used 10.0 and it converged... I also used a CFL of 1.5 instead of 1
    Could it be that the inputting an integer number causes convergence troubles? I'm pretty sure all the rest was set properly
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Rishi Shenoy
    Hi Rishi,
    yes this makes sense. If you increase the iterations there is more "time" to converge for the solver, but it also takes longer. But actually challenge 2 should converge with default settings. Let's try to understand which setting could be wrong. Could you please provide me screen shots of the following:
    • The generate grid. Please choose a similar view as in the hand-out
    • Properties of:
      • Domain: Physics - standard settings
      • Domain: Initial solution - standard settings
      • Domain: Numerics - standard settings
      • Boundary condition: duct wall - standard settings
      • Boundary condition: inlet - standard settings
      • Boundary condition: outlet - standard settings
    Best regards
    Manuel
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Commodaro
    Hi Commodaro,
    this should actually make no difference. I always enter the value without decimals (if not needed). Please try the following: enter 10 and the click with the mouse into another field. It should be then expressed as 10.0. To understand where the problem is coming from, may I ask you to do the same as Rishi above please. Could you please provide me screen shots of the following:
    • Properties of:
    Best regards
    Manuel
