  2. Online CFD Course
  3. Creating vector fields doesn´t work
  • State Verified Answer
  • Subscribers 9
  • Views 2492
Samjon
Samjon over 3 years ago
When I want to create a vector field on a cutting plane or any other, it is only creating a field of dots without any vectors, though the field's statics are showing velocities above 0 m/s.
Result analysis is running and enlarging or fitting the vectors doesn't help.
Is there any way to fix this?
  • Manuel NIB
    Manuel NIB over 3 years ago +2 verified
    Hi Samjon, we had this question also in the Q&A. Not sure if you asked it. This issue coming from the graphics card. Could you please check that you are using the latest driver version from the graphics…
  • Manuel NIB
    +1 Manuel NIB over 3 years ago
    Hi Samjon,
    we had this question also in the Q&A. Not sure if you asked it. This issue coming from the graphics card. Could you please check that you are using the latest driver version from the graphics card. Which graphic card model do you have? Do you have potentially 2 graphic options (e.g. a GPU unit inside an Intel CPU and a separate dedicated graphic card)?
    Best regards
    Manuel
    • Vote Up +2 Vote Down
