  2. Online CFD Course
  3. Unable start software.
  • State Verified Answer
  • Subscribers 9
  • Views 6995
SURYA45
SURYA45 over 3 years ago
Hello Everyone,
my software had some problems. I did challenge 1 without a problem but now I can't open my software. Please check below Image.
Thank you.
  • SURYA45
    SURYA45 over 3 years ago in reply to SURYA45 +2
    I download the license file again and follow the installation process again (as mentioned is the " Cadence CFD free student version" mail) and now it's working. Thank you.
  • AnasY
    AnasY over 3 years ago in reply to Manuel NIB +2 verified
    Hi Manuel, I just wanted to let you or anyone who has a similar problem know, that i had the same problem earlier today which got solved by re-activating the license in the Admin Tool as you suggested…
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to SURYA45 +1
    Hi Surya, thank you for the update. I'm glad it is running now again. I did a bit of research: Did you maybe install Windows updates. In some cases (depending on the type of update), the license needs…
  • Manuel NIB
    0 Manuel NIB over 3 years ago
    Hi Surya,
    the screen shot you sent us indicate that the license server on your computer is running. It typically needs around 2 minutes after a restart until the license server is running. If you open Omnis before, you won't get a license. Did you check that after this time frame Omnis is still not starting? For the activation you need to choose option License server name. Here you need to provide the name of the license server. As I assume that the license server is your computer, it would be the name of your computer.
    Best regards
    Manuel
  • SURYA45
    0 SURYA45 over 3 years ago in reply to Manuel NIB
    I try with my License server name but its shows....(SURYA is my hostname)
    another question. do you see 2 images in the license file validity? why the finemarine is selected there? Please help me. Tomorrow is the last day to submit challenge 2.
  • SURYA45
    0 SURYA45 over 3 years ago in reply to SURYA45
    I download the license file again and follow the installation process again (as mentioned is the "Cadence CFD free student version" mail) and now it's working. Thank you.
    • Vote Up +2 Vote Down
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to SURYA45
    Hi Surya,
    thank you for the update. I'm glad it is running now again. I did a bit of research: Did you maybe install Windows updates. In some cases (depending on the type of update), the license needs to be activated again.
    Best regards
    Manuel
  • AnasY
    +1 AnasY over 3 years ago in reply to Manuel NIB
    Hi Manuel,
    I just wanted to let you or anyone who has a similar problem know, that i had the same problem earlier today which got solved by re-activating the license in the Admin Tool as you suggested. The Problem was caused when Omnis crashed/stopped responding, so i had to close Omnis.exe through the Windows Task-Manager. After opening Omnis again i was required to enter an activation key/license server name as in Surya's first screenshot, also if i remember correctly i additionally had a license error message below the "license server name" field.
    Best regards
