  2. Online CFD Course
  3. CFD Course _ ERROR: residual of Mass is Not A Number: the...
  • State Verified Answer
  • Subscribers 9
  • Views 4615
CFD Course _ ERROR: residual of Mass is Not A Number: the solver has been stopped
NicoBu
NicoBu over 3 years ago
I always get the following Problem while simulating the half body with a CFL-Number of 3...
<img src="qrc:/warning"/> The simulation Simulation Half_CFL3 has failed: some NaN have been detected during the computation.<br> ERROR: residual of Mass is Not A Number: the solver has been stopped
How can I fix this?
Kind regards
  • Manuel NIB
    Manuel NIB over 3 years ago +1 verified
    Hi NicoBu, when the output of the flow solver during the iterations beomces NaN (not a number) it means that teh simulation has diverged. This question also came up during the Q&A of class 1, in case…
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to NicoBu +1
    Hi Nico, it's good you double checked that! Best regards Manuel
  • Manuel NIB
    +1 Manuel NIB over 3 years ago
    Hi NicoBu,
    when the output of the flow solver during the iterations beomces NaN (not a number) it means that teh simulation has diverged. This question also came up during the Q&A of class 1, in case you want to check out the answer in the recording.
    A diverging simulation can have many different reasons, but one is that the CFL number has been set too high for a particular flow application (sometimes the flow is too complex to converge with CFL=3 and we need to apply a lower CFL number). As this class is also about numerical stability, I cannot go further into detail.
    Does that help you?
    Best regards
    Manuel
  • NicoBu
    0 NicoBu over 3 years ago in reply to Manuel NIB
    Hi Manuel,
    thanks for your quick response. I already thought that this could be the problem but I was not shure about it. Therefor the thread in this forum.
    Kind regards
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to NicoBu
    Hi Nico,
    it's good you double checked that! Slight smile
    Best regards
    Manuel
