  2. Online CFD Course
  3. Epsilon in initial solution and boundary condition
  • State Verified Answer
  • Subscribers 9
  • Views 3691
MaxiWei
MaxiWei over 3 years ago
Hi all,
is it correct that the value of epsilon change with the factor 10 between the initital soluttion and the boundary conditions?
Or is only the value of 0.7547 m2 /s3 correct? I think it's a typing error, but I just want to make sure. :)
Thank you very much!
Best regards
Max
  • Manuel NIB
    Manuel NIB over 3 years ago +2 verified
    Hi Max, this difference is actually intended. The final correct value is set for the inlet boundary condition. For the initialisations it is advantageous for the convergenc, if 1/10 of the expected value…
  • Manuel NIB
    +2 Manuel NIB over 3 years ago
    Hi Max,
    this difference is actually intended. The final correct value is set for the inlet boundary condition. For the initialisations it is advantageous for the convergenc, if 1/10 of the expected value for epsilon is set. That is a difference to all other quantities for the initial solution.
    Good you are asking! We will note down to put a comment there for the next round of the CFD Online Course.
    Best regards
    Manuel
    • Vote Up +2 Vote Down
