  2. Online CFD Course
  3. Mesh generation fails (some process did not pass initialization...
  • State Verified Answer
  • Subscribers 9
  • Views 6307
Mesh generation fails (some process did not pass initialization)
VitusR
VitusR over 3 years ago
Hi, when following along the Module 3 I get following Error Message when trying to start the Mesh generation:
M_Mesh Setup Full Error: some process did not pass initialization
This happens using the "Full" Choice, with the Seedpoint beeing inside the Geometry and underneath (-z) the Symmetry Plane.
Can one of you tell me what I did wrong? Thanks in Advance!
  • VitusR
    VitusR over 3 years ago in reply to VitusR +2 verified
    Redoing the whole thing worked
  • Manuel NIB
    0 Manuel NIB over 3 years ago
    Hi Vitus,
    could you share with me please the coordinates of your seed point? You find the coordinates of the seed point in the domain context:
    Too me it looks a bit like the seed point might be too close to the wall, but that is just an assumption. Usually you also get a warning message display, if that is the case.
    Just to be sure: Did other mesh generation run already succesfully?
    Best regards
    Manuel
  • VitusR
    0 VitusR over 3 years ago in reply to Manuel NIB
    Hi Manuel,
    yes I can, but I put the seed point in about 20 differrent spots and it didn't change the error message.
    1.683386 -0.003455 -0.140219.
    I tried creating a random Mesh in a different project, that worked flawlessly.
    So far mesh generation never made any problems. I tried redoing the Mesh Setup, the same Error Occurs.
    I will try doing the whole exercise again, but I probably wont get to do the Challenge in time so I'm worried about not passing the Course.
    Do you have any other ideas what could be wrong?
    Best Regards
    Vitus
  • VitusR
    +1 VitusR over 3 years ago in reply to VitusR
    • Vote Up +2 Vote Down
