  2. OpenLabs
  3. pressure far field boundary condition
  • State Verified Answer
  • Replies 7
  • Subscribers 6
  • Views 16343
sriluta
sriluta over 4 years ago
Hey, I am investigating the flow in a turbine with only one stator. For the outlet I would like to set a pressure far field BC, because I don't now the static pressure in the outlet. For this I have extended my domain length by 20 times the chord length of the blade. So how can I set this BC, with the Bc external for the outlet ? Iam using Omnis v2,
thx
  • domen
    domen over 4 years ago in reply to sriluta +1 verified
    If you know the throat area you can get the flow that can pass through, using that formula. Or you can just apply different levels of pressure at the outlet until the nozzle is choked and get the operating…
  • domen
    0 domen over 4 years ago
    Hello!
    forgive my curiosity, but for a far-field BC you still need the static pressure. What would be the advantage of a far-field in this case?
    In Omnis you should be able to set the external BC by changing the type:
  • sriluta
    0 sriluta over 4 years ago in reply to domen
    Hello, thx for reply. Ah so the typ selection to " external" was right, as I thought :)
    so i would like to use a fixed bc for the outlet. If all flow fluctuations up to the outlet are damped, then I can also use such a boundary condition. To do this, I run several simulations and change my domain length for this, if the flow becomes independent of the domain length, it fits, otherwise I try to find the domain length until all fluctuations are damped. And for this I use a far-field boundary condition at the exit. Ah okay, well maybe I can estimate the static pressure also with rule of thumb ?
    I am investigating a compressible flow, have defined the total pressure, total temperature and velocity angle ("Arctg(Vt/Vz)" at "Angle from axial direction") at the inlet, then the mentioned far field boundary condition with a static pressure at the outlet. Unfortunately, my solution diverges with a 100% mass error. The exit mass flow is 0 kg/s
    ( hmm, I see now for the external setup I didn't use the same Values of k and epsilon like in the inlet maybe this is the mistake ? )
  • domen
    0 domen over 4 years ago in reply to sriluta
    For EXT BC, the mass flow rate is zero. The solver doesn't output how much mass is flowing in or out of the domain.
     Generally, we avoid EXT conditions when we can use a simple static pressure: the far-field requires the knowledge of the velocity and it must be placed really far from any gradient. Static pressure is a much more robust condition.
  • sriluta
    ah thank you very much for this information, my supervisor also rather advised me against this bc. Do you know how I could estimate the static pressure at the outlet with a rule of thumb ? I have the total pressure at the inlet, I could possibly find out the total loss from the literature.
  • sriluta
    0 sriluta over 4 years ago in reply to sriluta
    maybe with these formula ? So its the total pressure to static pressure ratio but for isentropic flow. Therefore I I would subtract the total pressure drop from the total pressure at the inlet and with a Mach number at the outlet I could estimate the static pressure ? Or maybe an easier way ? :)
