  2. OpenLabs
  3. Cavitation with Thermodynamics table issue
  • State Verified Answer
  • Replies 8
  • Subscribers 5
  • Views 14909
JosephSmith
JosephSmith over 3 years ago
Greetings,
I have been attempting to use thermodynamic tables to simulate cavitation within a turbopump. Water was the working fluid. However, I have been getting a run time error right at the beginning of the simulation – this is seen in the attached log file I copied.
Fullscreen 3146.thermotable error.txt Download
Try to spawn hexstreamdpx86_64.exe on MechStu OS: WIN32 with Login:
Argument 1: none  C:\Users\user\Desktop\December\EO_RC_0_12\EO_RC\EO_RC_cav_thermotables_0_05\EO_RC_cav_thermotables_0_05.run
Argument 2: -taskmanager  none
Argument 3: -steering  C:\Users\user\Desktop\December\EO_RC_0_12\EO_RC\EO_RC_cav_thermotables_0_05\EO_RC_cav_thermotables_0_05.steering
Argument 4: -niversion  open111
Argument 5: -parendId  262166
start_status_ok
TRYRECONNECTED_TO_CHILDREN
SUBTASK_RECONNECTED_TO_CHILDREN
ASK FLOW SOLVER STEERING
FLOW SOLVER STARTED
PVM initialization done.
Block master processes write to std, all others write to log
version 11.1 double-precision.
Trying to read project C:\Users\user\Desktop\Vedanth\December\EO_RC_0_12\EO_RC\EO_RC_cav_thermotables_0_05\EO_RC_cav_thermotables_0_05
Restart and reset convergence history
FMG deactivated
Checking for coin license
Reading the database
WARNING - The option 'Allow Multiple Domains Per Process' is not compatible with PartitionerParallel_ = 0
WARNING - Automatic swith to parallel partitioner, PartitionerParallel_ = 1
Database opened and read successfully
RESET FLOW SOLVER STEERING
STEERING HAS BEEN RESET
Checking module licenses
All licenses checked out!
 in progress...
 in progress...
For incompressible fluids, the pressure switch is disconnected
WARNING - For One Equation Turbulence Models tm_iResSmoo_ = 2 not allowed
 --> Setting tm_iResSmoo_ = 1
No transition point file
Initial solution in cylindric coordinates
 In Turbomachinery output mode, the expert parameter out_gaugeForceTorque_ is automatically reset to 0
Checking for CAVITATION coin license in PARA
Initial solution in cartesian coordinates
Number of grid levels to generate = 4
correction for non-matching connections (if existing)
Saving C:\Users\user\Desktop\\December\EO_RC_0_12\EO_RC\EO_RC_cav_thermotables_0_05\EO_RC_cav_thermotables_0_05_p0.dtw file
Solver has started
Start solving the testcase on current grid
Computing solution on fine grid
Output of solution to files for block 0 (fluid)
Finished output to files for block 0
Output of solution to files for block 1 (fluid)
Finished output to files for block 1
    iter adapt_id    local             var          res-av         res-max         res-abs     cellID
       1        0        1            Mass    0.000000e+00    0.000000e+00    3.575875e+10      46511
       1        0        1            Mass    0.000000e+00    0.000000e+00    5.770544e+10     546440
I followed the parameter guidelines in the FINE Open user and theory guide when using the thermodynamic tables option (I first changed the iCavitation_ value to 2 then changed the rest of the parameters locally in the advanced Control variables tab). The initial solution was taken from a converged run without cavitation models. This initial solution worked with the Barotropic cavitation model but not with Thermodynamic tables.
I’m still in the process of troubleshooting possible ways of where the error lies. Not certain if its relevant to the error, but I did not understand what the user manual meant by using thermodynamics tables in the Physical configuration > Fluid model page, seen in attached image.
I would appreciate any assistance on the error or to what the manual referred to for the former.
Kind regards,
Joseph
  • BIPal
    BIPal over 3 years ago in reply to JosephSmith +2 verified
    Hi Joseph, Here's a few options you could try: Try imposing velocity at the inlet and static pressure at the outlet. This is a more robust b.c. combination. Try progressively reducing the CFL…
  • BIPal
    BIPal over 3 years ago +1
    Hi Joseph, I don't see any errors in the log file, but I see that the initial residuals are very high. Is it possible that the error was cut-off/not copied? Regarding your question, the documentation…
  • BIPal
    BIPal over 3 years ago in reply to JosephSmith +1
    Hi Joseph, The warning seen above shouldn't cause any problems. It appears to be issued by the Qt version packaged with TabGen. Regarding your first question - I meant that I don't see any errors…
  • BIPal
    0 BIPal over 3 years ago
    Hi Joseph,
    Regarding your question, the documentation is referring to changing the fluid model to condensable gas. You will then have to define the path to the table containing the fluid properties.
    Best regards,
    Botond
  • JosephSmith
    0 JosephSmith over 3 years ago in reply to BIPal
    Hi Botond,
    Thank you for the reply. Sorry, what do you mean by "cut-off/not copied"?
    I missed that and previously did not select the tables_water_steam as the fluid. I have changed it now but still seem to be encoutnering the large initial residuals. I will try out different boundary conditions.
    On a different note, I was met with a error when trying to open tabgen, stating it is an untested version of windows detected seen in the text file. I doubt it is related to the previous problem but wanted to know if they is an alternative to opening it on this version of windows 10?
    Fullscreen tabgen error.txt Download
    Qt: Untested Windows version 6.2 detected!
      <***>   tabgen 16.1  -  MS Windows x86-64  -  Feb 20 2021   <***>
    Kind regards,
    Joseph
  • BIPal
    0 BIPal over 3 years ago in reply to JosephSmith
    Hi Joseph,
    Regarding your first question - I meant that I don't see any errors in the log file. It seems to end abruptly.
    Best regards,
    Botond
  • JosephSmith
    Hi Botond,
    I see.
    Alright, thanks for the confirmation. I will interrogate my cavitation setup again
    regards,
    Joseph
  • Colinda
    0 Colinda over 3 years ago in reply to JosephSmith
    Hi JosephSmith
    Could you find the cause of trouble in your setup?
    Best regards,
    Colinda
