  2. OpenLabs
  3. Unsteady inlet boundary condition with OpenLabs
  • State Verified Answer
  • Subscribers 7
  • Views 8502
sriluta
sriluta over 3 years ago
Hey, I have at my inlet three Boundary conditions that changes with time and the azimuth angle. Arctg (Vt/Vz), Absolute total pressure and the absolute temperature. In the Inlet of my domain, I import the profiles, that changes with the azimuth angle. Now I want to change these profiles with the time too and I need to use OpenLabs for. In the tutotorial of OpenLabs I saw a expression with a sine function ( tutorial 2: customized unsteady Inlet boundary condition), but I don't like to use that. Is it possible to use an array of values ?
For example my time step is 0.000011s. At an azimuth angle of 0 degree I have a total pressure of 1 Bar and the time is 0. At an azimuth angle of 90 degree a have a total pressure of 2 bar and the time is 0.000011s. At an azimuth angle of 180 degree I have a total pressure of 3 bar and the time is 0.000022s and so on, is that possible ? I don't like to use a function here for.
Iam simulating a stator..
greetings Hussein
  • Colinda
    Colinda over 3 years ago +1
    Hi Hussein, You could use a discrete expression in OpenLabs to define the total pressure and total temperature as a function of time and the azimuthal angle. Are you using OpenLabs in Fidelity or Fine…
  • Dianliang
    Dianliang over 3 years ago in reply to Colinda +1
    Just to complete, you can search discrete expression on support.cadence.com to find the relevant documentation (Implicit and discrete expressions) for Fidelity or Fine Open.
  • sriluta
    sriluta over 3 years ago in reply to Colinda +1 verified
    Hey, thx for your response. I use now the functions of the fourier series, as functions of the time and the azimuth angle :), iam using openLabs in Omnis 5.2
  • Colinda
    0 Colinda over 3 years ago
    Hi Hussein,
    You could use a discrete expression in OpenLabs to define the total pressure and total temperature as a function of time and the azimuthal angle. Are you using OpenLabs in Fidelity or Fine Open? Which version are you using?
    Best regards,
    Colinda
  • Dianliang
    0 Dianliang over 3 years ago in reply to Colinda
  • sriluta
    +1 sriluta over 3 years ago in reply to Colinda
  • WS202504245114
    0 WS202504245114 over 1 year ago in reply to Dianliang
    I couldn't find any information related to "discrete expression" on support.cadence.com.
  • Dianliang
    0 Dianliang over 1 year ago in reply to WS202504245114
    Did you log in the support portal? The first return of the search should be the answer.
    Alternatively, you can go to Product Manuals -> Silicon-Package-Board Co-Design -> Computational Fluid Dynamics -> Fidelity 2024.2 -> Setting up a simulation -> Optional models -> OpenLabs -> OpenLabs language -> Implicit and discrete expressions
