  2. Pointwise
  3. Connect inflation layers around a corner between two split...
  • State Verified Answer
  • Replies 13
  • Subscribers 10
  • Views 18986
Connect inflation layers around a corner between two split bodies
IE202408012526
IE202408012526 over 2 years ago
Hello everyone,
I am using Pointwise to create a inflation layer around a corner between 2 bodies.
I want to define a porous zone in one of the bodies, therefore I cannot connect them directly and create all inflation layers together because I need seperate blocks for each volume.
The current status of my mesh is shown in the 2 pictures below:
Is it possible to connect the inflation layers in an angle of 45 degress or similiar to that, maybe as some kind of boundary condition in the extrude settings when creating the boundary layers?
An example of what I would like to get is shown in this picture:
But then I can't treat them as 2 seperate bodies / blocks anymore.
Do you have any advice?
Thank you very much!
  • Claudio M Pita
    Claudio M Pita over 2 years ago in reply to IE202408012526 +2 verified
    Hi, Thank you very much for the update on this. Unfortunately, it is hard to understand your T-Rex set up and to answer your questions by looking at two images. At this point, I would recommend you…
  • Claudio M Pita
    Claudio M Pita over 2 years ago +1
    Hi, Thank you very much for your question. Unfortunately, it is a bit hard for me to understand the block topology in this case. In other words, I am not understanding where each block ends. Is there…
  • Claudio M Pita
    Claudio M Pita over 2 years ago in reply to IE202408012526 +1
    Hi, Thank you very much for the information. Yes, I would recommend using the T-Rex algorithm as it will allow you to create the grid that you are looking for in a fraction of the time. Furthermore…
  • Claudio M Pita
    0 Claudio M Pita over 2 years ago
    Unfortunately, it is a bit hard for me to understand the block topology in this case. In other words, I am not understanding where each block ends. Is there any chance you can post some additional images to understand this; or perhaps a very simple Fidelity Pointwise file showing this particular topology?
    In addition, it seems that you are using a regular extrusion to create the boundary layers. Have you tried using the T-Rex algorithm for this?
    Thanks much!
  • IE202408012526
    0 IE202408012526 over 2 years ago in reply to Claudio M Pita
    of course. I am using a CAD model and create the blocks from its topology.
    Here you can see the white part. This should be the block with inflation layers defined as a porous volume.
    The other part above is a different block and both inflation layers should be connected.
    The connected inlation layers should be around the edges like the red lines you can see here:
    I haven't tried T-Rex for this yet, I only used the normal extrusion. Do you think this would work better?
    Thanks for your help!
  • Claudio M Pita
    0 Claudio M Pita over 2 years ago in reply to IE202408012526
    Yes, I would recommend using the T-Rex algorithm as it will allow you to create the grid that you are looking for in a fraction of the time. Furthermore, I would also recommend using the Automatic Surface Mesh (ASM) and Automatic Volume Mesh (AVM) tools to complete the grid in a fraction of the time.
    Please note the following:
    • The first step when creating a grid is "preparing" the CAD data for meshing. This includes assembling everything into a single watertight solid model and assembling the quilts as needed to defined the desired meshing regions.
    • Once the above is done, you can use ASM to quickly create the surface grid (domains).
    • Once you have the surface grid, you can use AVM to create the volume grid (block).
    If you are not familiar with the above workflow, I would recommend reviewing the following:
    • Basic Concepts: https://youtu.be/7ynTrsuG80I?si=o1EiaEc-raqmO8Wg
    • ASM: https://youtu.be/VmAYwRbChMk?si=7_cfopgR3sMwEI_O
    • AVM: https://youtu.be/EU1Cb2KeK-U?si=UOangATVOOK4iZCw
    • Also note that you have a wealth of material in the User Manual (Help, User Manual) that will guide you through the most efficient mesh generation process.
    I hope this helps.
  • IE202408012526
    Thank you for your help.
    I am aware of the workflow you mentioned above. I only looked for a smooth way to connect both inflation layers.
    I will try the T-rex algorithm.
    Thank you very much.
  • Claudio M Pita
    Thank you very much for your quick reply.
    It is good to hear that you are familiar with the recommended workflow.
    You will likely generate the smoothest (and faster) grid with the use of ASM to create the surface grid and AVM to create the two blocks. Inside AVM, you will be able to set up the T-Rex algorithm for each block with the corresponding boundary conditions.
    Thank you very much for your time.
